Went to the dyno.
Old Dec 4, 2009 | 07:08 PM
blownss06's Avatar
Default Went to the dyno.
This is my first post. Here is the dyno sheet.
Now a little info on the truck.
06 Silverado SS
Magna Charger with 3in. pulley 7psi
Long tube header with full exhaust
160 t-stat
Taylor 10.4 wires with NGK TR-6 plugs
Shift Kit with 2and4 servos
C.A.I
Custom tune.
One problem I am having is that my AFR is lean 12.4 and my injector duty is at 96%. I was told to switch to 8.1 marine injectors. I post over on SilveradoSS site and need advice.
Thanks
Old Dec 4, 2009 | 07:10 PM
charcoal03silvy's Avatar
Looks good, but the toque graph looks funny
Old Dec 4, 2009 | 07:11 PM
00ChevyScott's Avatar
Wearin' da big hat
376hp at 7psi?
That doesn't sound right at all....
Old Dec 4, 2009 | 07:13 PM
viciousknid's Avatar
Where's the Beef?
is that a stock cam?
Old Dec 4, 2009 | 07:15 PM
Can't be TOO big with the HP and torque falling off like that
Old Dec 4, 2009 | 07:18 PM
Where's the Beef?
I checked on that dyno brand and they read LOW. Lower than a Mustang Dyno.
Old Dec 4, 2009 | 07:21 PM
blownss06's Avatar
Stock cam.
Old Dec 4, 2009 | 07:30 PM
BlackGMC's Avatar
Resident Retard
Actually that type of dyno reads correctly all other inflate the numbers.... Dyno Dynamics is a load bearing dyno...
Old Dec 4, 2009 | 07:40 PM
If it's a real SS Silverado,it should be AWD.It would lower the numbers a bit.Right ?
And if you have a magnacharger kit,I thought it would come with 42 lbs injectors allready?
Old Dec 4, 2009 | 08:18 PM
blownss06's Avatar
03-04 SS where AWD 05-06 SS RWD. yes it has the original magna charger injectors. I dont know what the LBS are
