ON3 Kit is here! 6.0 RCSB 4x4 Silverado build
Old Aug 30, 2014 | 08:20 PM
  #31
GMCtrk's Avatar
No it wont overheat. As long as you the truck doesn't get to hot you could probably get by without it. With heat the coolant expands hence the tank is there to contain the extra volume. It contracts when the coolant cools down.
Old Aug 30, 2014 | 08:28 PM
  #32
TRD_Tundra's Avatar
Nice nice.. I still have my stock upper radiator hose and just noticed On3 doesn't provide the filler neck. Hopefully auto parts stores have them
Old Aug 31, 2014 | 03:11 AM
  #33
caliSSclone's Avatar
Subscribed badass truck badass build
Old Aug 31, 2014 | 07:52 AM
  #34
YoungBoss's Avatar
Dam everything came out very nice, if you don't mind how much more was it to upgrade turbo? Also here is an option for a catch can/overflow tank, guys name is Aldo welds on fb and he does some sick as work.
Hey custom made everything and welded the fitting to my valve covers.
Old Aug 31, 2014 | 01:27 PM
  #35
TRD_Tundra's Avatar
I'm familiar with Aldowelds, if I'm not mistaking I believe hes a fabricator for D3 or used to. Turbo upgrade was $200 If I remember right.
Old Aug 31, 2014 | 01:47 PM
  #36
YoungBoss's Avatar
Yea he use to work at D3 now he has his own shop. dam only $200?? if the original turbo is good for 8lbs how much more boost will the upgraded turbo make?
Old Sep 1, 2014 | 05:16 PM
  #37
TRD_Tundra's Avatar
Little update.
Cold side done
Only issue I faced in the cold side was the 3" to 4" coupler not fitting my BBK 92mm TB. So I bought a 3.5" to 4.5" coupler from Home Depot.
For the Hot Side.
Closing the V-band from the crossover pipe to the Log was a PITA cause it was nearly impossible to get it aligned and clamp it down(a second hand would make things much easier here)
The hot side I needed a 1/4" shorter bolt so instead of rushing the hardware store I modified the V-Band.
This is where I tapped the Oil return line using a 9/16" drill bit and a 3/8 NPT Tap.
Wired up the AEM TRUBOOST controller, Trans temp, and water temp gauges.
This is how it looks "Nearly" Finished, just need to bolt down the BOV but I'm waiting til my FIC 1000cc injectors come in to avoid building any boost.
And here is a quick Idle clip. Local exhaust shops were closed today so I can get the Downpipe connected to my Dual orsa sport exhaust set-up.
https://www.youtube.com/watch?v=6GuL...ature=youtu.be
Old Sep 1, 2014 | 05:28 PM
  #38
brewster240's Avatar
i love this truck.
thanks for the detailed pics, im gonna be ordering a kit soon, and they will help for sure.
Old Sep 1, 2014 | 05:31 PM
  #39
Three6GMC's Avatar
looks really good how much is the whole kit by the way?
Old Sep 1, 2014 | 05:36 PM
  #40
TRD_Tundra's Avatar
With the 70mm it's $1970 Shipped. I got chose some upgrades such as the 78/75 turbo, mesh air filter, sparkplug wire set, and a DP for the wastegate to vent to atmosphere. Witch was an additional $300-400 from the initial price.
