ON3 Kit is here! 6.0 RCSB 4x4 Silverado build
Old Aug 28, 2014 | 11:38 PM
TRD_Tundra's Avatar
Default ON3 Kit is here! 6.0 RCSB 4x4 Silverado build
Everything is finally coming along. On3 kit is here and planning on taking advantage of this long weekend to install it.
Little history on the truck it's a 2000 Silverado originally a 5.3 z71, swapped out front ends to a 2006 and had it painted completely in and out Tuxedo Black with Metallics(Ford Color (._. ) ) and dropped in an Lq4. Lowered it 5.5/8, 22x8.5/22x10 Billet Specialties wheels and a few other cosmetic mods.
During a cam swap the lq4 had a hurt cam bearing so I pulled it out for a rebuild and used LS2 pistons and rods.. So pretty much an Lq9 now
After 4000 miles or so I had a Pac 1218 spring fail on me (228r cam) while idling but luckily there was no major damage done. At that point I got me some LS3/L92 SDPC CNC'd heads w/ Manley valves and .675" double springs hand port finished milled to 66cc, TickPerformance Stage 1 LS3 cam, and L92 intake.
That same week I swapped in a freshened up 4l80e w/ shift kit and pump mod, Circle D 4000 Multidisk, High speed 1 piece DS, and rebuilt the rear end w/ a Trutrac unit and 4.10's
Other than that the original plan was to go nitrous, bought everything for a nitrous set-up and all the goodies for it but ON3's kit was just too tempting so I had to go with it.
The welds on the Hotside are great! The cold side not the best but still decent since theres only 2 welds total. Everything feels great and good quality.
I'm still waiting on these parts to arrive:
-Yank ProTruck 3200 Multi-disk
-FIC 1000cc injectors
-2 AEM 320lph pumps
-Need to order a Map Sensor
Plans of now is to run it on E85 starting off at 7psi and slowly ramping it up to 10-12psi on their new 78/75 turbo.
Still need to Fix:
-Figure out how to get the NP263HDx transfer case working
-Front Driveshaft
-Most importantly fix the A/C. For some reason it quit working again.
Old Aug 29, 2014 | 12:28 AM
oakley6575's Avatar
Looking forward to seeing progress this weekend man. The On3 kit looks killer. I'm pretty impressed since it cost about half the price of my kit
Old Aug 29, 2014 | 02:05 AM
07NNBSVMAX's Avatar
So shiny
In for the build.
Old Aug 29, 2014 | 09:03 AM
GXPJAY's Avatar
VERY sweet looking truck! Going to be a fun weekend!!
Old Aug 29, 2014 | 09:38 AM
07bluelbz's Avatar
Man I'd like to see this kit in person. Maybe we can meet up at RPR some day. Truck is beautiful BTW.
Old Aug 29, 2014 | 12:48 PM
TRD_Tundra's Avatar
Weather hasn't cleared up and no progress has been done yet. Only hick-up I see during this installation is the oil drain line. It's going to be a PITA to drop the oil pan since I have to lower the front diff. I can't find any 3/8NPT drill bit's nor Taps in any hardware store
Old Aug 29, 2014 | 01:56 PM
Chavette's Avatar
I used step drill bit and an NPT tap set I bought from Harbor Freight a few years ago. I was able to remove the middle section of the front differential and squeeze the pan by...not as easy as everything out of the way but I thought it was less time.
Old Aug 29, 2014 | 05:26 PM
That friggen log looks killer!!! I have one of those 78/75's waiting to replace my mp70 but I must get a meth kit first. Cant wait to see it finished!!!
Old Aug 29, 2014 | 05:45 PM
TRD_Tundra's Avatar
Well'p the log doesn't fit with my AC compressor so I had to disconnect the lines.
Old Aug 29, 2014 | 05:55 PM
Please take some pics...your supposed to be able to keep A/C with this kit right??
