o2 sensor location on log manifold single turbo setup...
Old Jun 9, 2011 | 04:57 PM
91blowthru's Avatar
Default o2 sensor location on log manifold single turbo setup...
where are people locating the second o2 sensor on the single turbo log setups? (similar to KB Racing)
if i put both on the crossover, wont they be mainly reading only one bank?
i have a third o2 in my down pipe for my wideband...
this is my hot side,
Attached Thumbnails o2 sensor location on log manifold single turbo setup...-small4.jpg   o2 sensor location on log manifold single turbo setup...-s.jpg   o2 sensor location on log manifold single turbo setup...-ss.jpg   o2 sensor location on log manifold single turbo setup...-small.jpg
Old Jun 9, 2011 | 05:23 PM
black04's Avatar
Mine is right below the turbo flange on the log. It is a kbracing log so I am sure a lot of people run it like that.
Old Jun 9, 2011 | 06:59 PM
vicalma03's Avatar
That's how mine is, also a KB kit..
Old Jun 9, 2011 | 07:31 PM
FarmTruc's Avatar
Performance Trucks Sponsor
There's no way to read left and right bank with a single log setup. U loose left and right bank. But the good news is reads close enough and it'll work if u put the o2 where they said above or in the downpipe near the firewall area.
Old Jun 10, 2011 | 07:05 AM
91blowthru's Avatar
ok i understand where you are talking about in the log..
would it give you in innacurate reading to have one in the crossover and one in the downpipe(after the turbo) i just wanna make sure i do this right, i dont wanna have tuning nightmare on my hands...
Old Jun 10, 2011 | 01:30 PM
02'Z71ONDUBZ''s Avatar
In theory it should give you an inaccurate reading regardless of where you put them, but like Nelson said if you put it the bung in the log near your wastegate it will work well enough to keep your trims from jumping around in closed loop. It might work as well in the down pipe, but I wouldn't put it there. Save that for your wideband.
Old Jun 10, 2011 | 02:03 PM
black04's Avatar
Do you guys always get rich codes popping up even when your wide band reads normal?
Old Jun 10, 2011 | 02:16 PM
smokeshow's Avatar
Mod with training wheels
Negative, ghost rider. Sure your WB isn't dipping low at cruise?
Old Jun 10, 2011 | 02:32 PM
black04's Avatar
Nah it only does it after my truck sits for a few days. Then I drive my truck and when I am cruising at 30-40mph for a few minutes it'll pop up. When I clear it it goes away for a few days.
Old Jun 10, 2011 | 08:12 PM
LS1TRUCKGUY's Avatar
Your o2 sensor heater my be getting lazy
OHsixLS3
Dec 27, 2016 09:30 AM
Ls3silverado
Jul 31, 2015 04:22 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
wheeliE-maxx
Jul 19, 2015 05:37 PM
