No News on Duwem's Turbo Tractor, so let's Talk About Me.
As you'll remember, because I am the center of the universe and everybody remembers all of my posts, I had a PCV problem. I was trying to run PCV with no baffle in the PCV valve cover, it was removed for rocker clearance. I put a coalescing filter in the PCV line to catch the oil until I got around to doing the LS6 valley cover upgrade. I was dumping the bowl on the filter before every drive, and dumping a quart of oil in the engine when the "check oil level" light lit. I thought I might be sucking a little oil. and burning the rest because maybe the rings weren't yet seated. Well, I definitely was burning it, but all through the intake! I spent the day flushing out the blower, the inter-cooler, the piping and the intake manifold. Now maybe my boost will drop a couple of psi with the blower dry. I also put in a picture of an LS6 valley cover, I installed it before I realized I should have taken a pic of the underside to show how humongous the oil baffle is. I wonder if this oil burning would lower the fuel's octane enough to cause my knocking? http://homepage.mac.com/michaeldritz/PhotoAlbum20.html
Originally Posted by thunder550
Burning oil will definitely cause knock.
Originally Posted by 350SS
Holy **** is right... so I'm missing why you're getting oil in the blower in the first place. Did you run a hose from your valvecover to the blower inlet?
http://ls1howto.com/index.php?article=18
I wish I knew about when the engine was going together, it would be nice to only do it once.
I wonder if my engine builder was supposed to restrict the flow of oil to the top-end with my roller rockers, and didn't? I think it is probably all due to not having the baffle in the PCV-side cover. Yours sounds like what was being descibed in the LS1howto.com article, just an annoying amount.
