No News on Duwem's Turbo Tractor, so let's Talk About Me.
Old Mar 13, 2008 | 10:51 PM
MikeGyver's Avatar
Default No News on Duwem's Turbo Tractor, so let's Talk About Me.
As you'll remember, because I am the center of the universe and everybody remembers all of my posts, I had a PCV problem. I was trying to run PCV with no baffle in the PCV valve cover, it was removed for rocker clearance. I put a coalescing filter in the PCV line to catch the oil until I got around to doing the LS6 valley cover upgrade. I was dumping the bowl on the filter before every drive, and dumping a quart of oil in the engine when the "check oil level" light lit. I thought I might be sucking a little oil. and burning the rest because maybe the rings weren't yet seated. Well, I definitely was burning it, but all through the intake! I spent the day flushing out the blower, the inter-cooler, the piping and the intake manifold. Now maybe my boost will drop a couple of psi with the blower dry. I also put in a picture of an LS6 valley cover, I installed it before I realized I should have taken a pic of the underside to show how humongous the oil baffle is. I wonder if this oil burning would lower the fuel's octane enough to cause my knocking? http://homepage.mac.com/michaeldritz/PhotoAlbum20.html
Old Mar 13, 2008 | 10:52 PM
thunder550's Avatar
High on diesel fumes
Burning oil will definitely cause knock.
Holy ****, that's a lot of oil in your pipes!
Old Mar 14, 2008 | 10:06 AM
350SS's Avatar
Holy **** is right... so I'm missing why you're getting oil in the blower in the first place. Did you run a hose from your valvecover to the blower inlet?
Old Mar 14, 2008 | 10:27 AM
MikeGyver's Avatar
I wonder how much. I will find out when this tank empties if I still have to lower my boost. It has what is probably 96 octane, a 50/50 mix of 93 and 100 octane to make sure my knock wasn't false. This mix fixed the knock.
Yeah, I tapped a fitting into the inlet so that the PCV would only see vacuum. I was assuming that guys have problems with PCV and boost because they have their PCV going into the manifold, and PCV won't work in boost. And because I have a Whipple, the valve covers are reversed, so the PCV valve is in the front right cover. I picture the rocker boxes filling with oil during a WOT run, then I hit the brakes, all the oil goes forward, and then gets sucked straight into the blower.
Old Mar 14, 2008 | 10:41 AM
350SS's Avatar
Is the LS6 valley cover that much better as far as stopping oil from entering the pcv tract? I had no idea this was available thanks for posting up.
Old Mar 14, 2008 | 10:47 AM
MikeGyver's Avatar
http://ls1howto.com/index.php?article=18
I wish I knew about when the engine was going together, it would be nice to only do it once.
Old Mar 14, 2008 | 10:52 AM
03sierraslt's Avatar
Mine is setup similar to your but I dont get the oil consumption. I get about a tablespoon or so in my catch can every oil change. I also still have baffle in the vavle covers as well..
Old Mar 14, 2008 | 11:14 AM
350SS's Avatar
Nice baffle
Old Mar 14, 2008 | 11:29 AM
MikeGyver's Avatar
I wonder if my engine builder was supposed to restrict the flow of oil to the top-end with my roller rockers, and didn't? I think it is probably all due to not having the baffle in the PCV-side cover. Yours sounds like what was being descibed in the LS1howto.com article, just an annoying amount.
Old Mar 14, 2008 | 11:37 AM
How much did that valley cover run you?
