New member; 2010 Silverado 6.2, 6L80 + 80MM via modified Trick Performance kit VIDEO
Old Apr 16, 2014 | 10:11 AM
B_ROCKS_IT's Avatar
Default New member; 2010 Silverado 6.2, 6L80 + 80MM via modified Trick Performance kit VIDEO
Whats up!
Bought the truck in October, had the turbo system on at the end of Jan, loving this thing!
Heres a quick video I threw together of what footage I have of it: 6 2 80MM Silverado - YouTube
I dont know a whole lot about the capabilities of these trucks as far as their drivetrain: From what I've seen it looks like I have the 9.5" 14B rear?
I plan to build the trans next month so I can turn off the torque management and also get a good stall in this B***. and soon after be turning the boost up, I want 800 at the wheels till I build the motor next year for 1000.
Soon though, I will need to launch in 4wd, so I am concerned about the T-case, u-joints, front axles etc.
any pointers on what I can expect to break and what I can do to upgrade???
Thanks guys, happy to be on the site!
Old Apr 16, 2014 | 11:18 AM
TrickTurbo's Avatar
Truck Sponsor
Looks good.
Sounds great.
I noticed you routed the psi pipe off the compressor different then we do.
Old Apr 16, 2014 | 11:58 AM
B_ROCKS_IT's Avatar
Originally Posted by TrickPerformanceProducts
Looks good.
Sounds great.
Thank you,
Yeah that's the only way it would work with that turbo which I sourced elsewhere, it had a 3.5" psi discharge, and 4" hotside outlet
Old Apr 18, 2014 | 11:25 AM
B_ROCKS_IT's Avatar
Nobody has any info to share about the t case or anything on these trucks?
Old Apr 18, 2014 | 01:12 PM
Choda's Avatar
transfer cases and cv shafts hold power as long as they don't have lifts or nasty angles
Old Apr 18, 2014 | 06:25 PM
ZO6Ted's Avatar
There are plenty of members launching in 4wd with no issues whatsoever that run 10s and even 9s on stock cases and suspension as long as its not lifted or diesel. I would recommend limiting straps on the front end if you don't want to hop all over the track though.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
cbhedrick
Jul 20, 2015 10:12 PM
Moto733
Jul 12, 2015 10:25 PM
Cowboy17
Jul 9, 2015 08:22 PM
Deceptarado
Jul 8, 2015 05:24 PM
