New 2300 Massive intercooler. :)
Old Dec 17, 2010 | 06:13 PM
  #31
03sierraslt's Avatar
Originally Posted by TrickPerformanceProducts
1" thick.
Taller ls1 style injectors are only 5/8 taller
Old Dec 18, 2010 | 09:29 AM
  #32
wkdivr's Avatar
You'll need the long style injectors, 3"" long. There will be a little custom fab work on the fuel rails.
Old Dec 18, 2010 | 10:14 AM
  #33
TrickTurbo's Avatar
Truck Sponsor
After some real close looking at this. When the Bosch injector is installed and pulled all the way down. You can see the top groove level with the bottom of the fuel rail.
About .250 from the middle of the oring. I cannot see the oring in the rail at all.
Should seal. I can move the injector up and down right now but it appears to be staying engaged in the rail.
From all the way up to all the way down I am seeing right at .115 movement. Not much.
For a tighter fit.
We can do custom rails
Modify these rails
build small oring spacers for under the injector.
Custom injectors are a no go I think. Not real cost effective.
I took some pics. Post them up later.
Old Dec 18, 2010 | 10:49 AM
  #34
Bill I already have Siemens/Deka 72's (they are the talls)
Old Dec 19, 2010 | 11:58 PM
  #35
Lucille's Avatar
Part # for the 72lb 3 inch Deka injectors?
Old Dec 20, 2010 | 10:39 AM
  #36
TrickTurbo's Avatar
Truck Sponsor
Here are some final pics. Some are blurry, but you'll get the idea. The rail stops at the first groove on the 48lb injectors I was using. I could not see the oring.
You can see the size difference in the cores, plus the larger core is thicker.
Attached Thumbnails New 2300 Massive intercooler. :)-photo-54-.jpg   New 2300 Massive intercooler. :)-photo-52-.jpg   New 2300 Massive intercooler. :)-photo-53-.jpg   New 2300 Massive intercooler. :)-photo-48-.jpg   New 2300 Massive intercooler. :)-photo-49-.jpg
Old Dec 20, 2010 | 10:40 AM
  #37
TrickTurbo's Avatar
Truck Sponsor
and a few more.
Attached Thumbnails New 2300 Massive intercooler. :)-photo-50-.jpg   New 2300 Massive intercooler. :)-photo-51-.jpg
Old Dec 21, 2010 | 10:11 AM
  #38
Rat Raceway's Avatar
When will you be selling them?
Old Dec 21, 2010 | 01:24 PM
  #39
TrickTurbo's Avatar
Truck Sponsor
Now. Cost is 1300.00
Just need your blower set up here for the build.
Old Dec 21, 2010 | 08:27 PM
  #40
Holy *****!!! Is that for a kit with spacer?
How much for just the IC?
I will just have go with out if that's for just the IC...
