need some opinions
Old Nov 24, 2011 | 11:45 AM
lglowe's Avatar
Default need some opinions
Well I'm about to pull the trigger on a kb front mount kit with a t76mm magnum turbo. Gonna run 3.5 inch down pipe and 3.5 inch all the way back. Any way I just won't some opinions on what size exhaust housing to go with. Lots of ppl go with the .96ar and like it I believe but I'm keeping my nitrous plate kit and decided to spray this thing out of the hole up to around 5-6 psi with 50-75 shot. So I'm wondering if I should step up to a 1.15 ar to take even more advantage of this or stick with a .96? Setup is going in a 02 ex cab 2wd with lq4 triple 12 cam and a 4l80e with STOCK converter. Gonna run about 10#s
Old Nov 24, 2011 | 12:00 PM
bud8fan's Avatar
i would go with the larger ar for shure...i just changed my setup for the larger ar and turbo and couldnt be happier
Old Nov 24, 2011 | 12:04 PM
lglowe's Avatar
Any guesses when the 1.15 ar would start spooling without n20
Old Nov 24, 2011 | 12:09 PM
bud8fan's Avatar
my ar is the 1.22 and it spools full boost at 3500 with my circle d a1 converter and 3.42 gears...boost controller helps alot. mine doesnt open the waste gate untill i have reached full boost then it starts regulating pressure.
Old Nov 24, 2011 | 08:31 PM
02'Z71ONDUBZ''s Avatar
Is this a track only setup? If your gonna be driving it much off the track I sure wouldnt size the turbine housing based on spool time when you spray. Are the .96 and 1.15 both P-trim turbos? How quickly do you want it to spool under casual driving conditions?
Old Nov 24, 2011 | 09:30 PM
lglowe's Avatar
This is a dd. I going with q trim. I'm also keeping in mind traction so I might need a little more lag delay also. I dunno
Old Nov 25, 2011 | 09:14 AM
bud8fan's Avatar
same here...this truck has been to the track 4 times over the years.it's a bad *** street sleeper
Old Nov 25, 2011 | 09:17 AM
biggest ar you can get
Old Nov 25, 2011 | 11:27 AM
The 4l80 is gonna help you with traction. I think the best move you could make for your build would be to go with a good 3k converter. If you were planning for one, I would say go for the 1.15 ar for sure. The difference between my stock converter and my yank made a night and day difference on spool time. If i had stayed with the stock converter, i would have preferred a p-trim .96 because the verter wont load the engine enough to spool the turbo as well under part throttle. With the 3k yank and 1.0 ar q-trim, the engine is loaded so much more that this turbo seems like its just waiting to be unleashed at part throttle acceleration.
SloSVO
Nov 22, 2020 07:34 PM
AdaMax
May 16, 2016 11:35 PM
Tuckin15s
Sep 23, 2015 09:35 PM
MOBBN
Sep 22, 2015 08:07 PM
