need more fuel
Old Apr 26, 2009 | 07:20 AM
05crew's Avatar
Default need more fuel
im out of fuel and need to get a bigger pump. so should i put 2 255 in, or is there a single fuel pump out there that will do the trick? dont want to cut up the truck that bad. but im going after 900rwhp or so
Old Apr 26, 2009 | 08:56 AM
silver-mod-o's Avatar
Hunt&Fisherator
Aeromotive A1000.... LOL
Old Apr 26, 2009 | 09:14 AM
silveradol33's Avatar
A1000. I wouldnt mess around with all that other bull man, just do it once and be done. LOL, at making 900rwhp and not cutting the truck up.
Old Apr 26, 2009 | 09:35 AM
Hunt&Fisherator
I was going to ask, what kind of injectors?? you'll need more than a pump upgrade to handle that kind of power I'd think honestly... fuel lines, rails, and serious injectors.
Old Apr 26, 2009 | 09:43 AM
DrX's Avatar
DrX
I'm using a MagnaFuel pump. They have tuner versions good for continuous duty and up to 2000hp.
FUELAB also makes some high capacity pumps. They accept a 0-5V input to vary the duty cycle, so it can be boost or TPS referenced.
I think you'll be doing some mods to your fuel system other than a pump swap to support 900hp.
Old Apr 26, 2009 | 10:04 AM
gmc6.0's Avatar
hey drx what other mods upgrade did u do for fuel sorry for jumpin in.
Old Apr 26, 2009 | 10:50 AM
DrX's Avatar
DrX
Fuel system is still in pieces and not yet tested, but this sketch sums it up. Under cruising conditions the rails will be fed by the factory pump and be returnless. Under boost the big pump will kick in. FPR at the rails is set higher than the primary FPR that dumps into the surge tank. You could run it as a dual pressure system to get by with smaller injectors. The primary FPR maintains the full functionality of the SUV style OEM fuel module in the tank and allows for returnless operation under low-moderate demand conditions. The intank FPR is removed and blocked off.
Old Apr 26, 2009 | 05:09 PM
MikeGyver's Avatar
DrX, including every miniscule part, could you tell us how much money you have invested in your fuel system?
I think that would be very informative to people that think that they can "not cut up the truck so bad" and be able to support 900 HP just by adding a pump to their stock fuel system.
Your answer should be made a sticky to the question "What else do I need before I install my forced induction, I plan on making more than 650 HP?".
Old Apr 26, 2009 | 06:18 PM
05crew's Avatar
i really just want to make a number on the dyno... i want to have 650-700rwhp for the street. that magnafuel pump does it go in like the 255 did or not? i dont know a lot about the fuel side of thinks i know i just need it to go fast...the 60lbs inj. when will they fall off?
Old Apr 26, 2009 | 06:59 PM
hellbents10's Avatar
LS1Tech Sponsor
The a1000 route is the simplest, reliable way to do it, not to mention cost effective. At under $600 for the whole deal in parts. The 60's will carry you to about 850rwhp with 55-60psi base pressure.
