need more fuel
im out of fuel and need to get a bigger pump. so should i put 2 255 in, or is there a single fuel pump out there that will do the trick? dont want to cut up the truck that bad. but im going after 900rwhp or so
Aeromotive A1000.... LOL
A1000. I wouldnt mess around with all that other bull man, just do it once and be done. LOL, at making 900rwhp and not cutting the truck up.
I was going to ask, what kind of injectors?? you'll need more than a pump upgrade to handle that kind of power I'd think honestly... fuel lines, rails, and serious injectors.
I'm using a MagnaFuel pump. They have tuner versions good for continuous duty and up to 2000hp.
FUELAB also makes some high capacity pumps. They accept a 0-5V input to vary the duty cycle, so it can be boost or TPS referenced. I think you'll be doing some mods to your fuel system other than a pump swap to support 900hp. http://i114.photobucket.com/albums/n...nafuelPump.jpg http://i114.photobucket.com/albums/n...FUELABPump.jpg |
hey drx what other mods upgrade did u do for fuel sorry for jumpin in.
Originally Posted by gmc6.0
(Post 4189404)
http://i114.photobucket.com/albums/n...Fuelpumps2.jpg |
DrX, including every miniscule part, could you tell us how much money you have invested in your fuel system?
I think that would be very informative to people that think that they can "not cut up the truck so bad" and be able to support 900 HP just by adding a pump to their stock fuel system. Your answer should be made a sticky to the question "What else do I need before I install my forced induction, I plan on making more than 650 HP?". |
i really just want to make a number on the dyno... i want to have 650-700rwhp for the street. that magnafuel pump does it go in like the 255 did or not? i dont know a lot about the fuel side of thinks i know i just need it to go fast...the 60lbs inj. when will they fall off?
The a1000 route is the simplest, reliable way to do it, not to mention cost effective. At under $600 for the whole deal in parts. The 60's will carry you to about 850rwhp with 55-60psi base pressure.
