need Meth kit
Old Jun 14, 2006 | 11:58 PM
  #21
jephs422's Avatar
Originally Posted by kbracing96
Do I have to do everything for ya
http://www.devilsownonline.com/index.php
You stayed at a Holiday Inn Express, didn't you?
I swear I'm not lazy, for some reason the search button on every computer in my house is seems to be broken
Old Jun 15, 2006 | 12:01 AM
  #22
jephs422's Avatar
Okay, I just came across something that I don't quite understand. All of them have options for 2 bar map or 3 bar map. Why do I need to know this, or why does it matter? Am I not just setting it to come on at a certain boost? what does my map have to do with it?
Old Jun 15, 2006 | 12:34 AM
  #23
Rocket468's Avatar
If you have not switched out your map you will need to buy a 2 bar map and connector. This is so you can run a seprate map sensor for the controller to see boost. the factory 1 bar map only reads vaccum. Its up to you if you want to do a 2 bar tune and just swap out the 1 bar for 2 bar map. But will probley make your truck run better if the pcm knows there is boost and just no vaccum.
  #24
kbracing96's Avatar
They need to know which map you have or want to use so the start/full on psi will be right on the controller. 4 psi is a different map voltage on a 2 bar map sensor then a 3 bar map sensor. Your probably still running the stock 1 bar with your radix, so you would need to buy a 2 bar map form them and connect it to a vac source and hook it up to the controller. It's really pretty easy. I'm running a 2 bar speed density setup, so I just tapped into my existing 2 bar map.
2 bar will get you to 15psi of boost.
Old Jun 15, 2006 | 12:36 AM
  #25
kbracing96's Avatar
Damn you Chance, you beat me to it, Told ya I'd pimp your product if I liked it
Old Jun 15, 2006 | 12:41 AM
  #26
Rocket468's Avatar
glade you like it.
Old Jun 15, 2006 | 09:22 AM
  #27
seadoo's Avatar
alky control as the best CS
The engineer (how builds the kits, and makes the micro processor) is one of the smartest people I have ever met when it comes to that stuff.
the owners TTA.... it its a stock weight (3750) original stock susp., stock motor, TE61 turbo, 22psi on 16" DR's ran 11.0-11.2 on shake down passes on weak foot brake launches. their dual nozzle, on 93
Old Jun 15, 2006 | 10:16 AM
  #28
Mort's Avatar
Cool
My .02 goes to AlkyControl as well. I just upgraded to Julio's system and I just got it yesterday and hope to install it before too long.
Old Jun 18, 2006 | 10:05 AM
  #29
MikeN's Avatar
Try using this unit from Snow?
Old Jun 21, 2006 | 05:17 PM
  #30
chopperbrent's Avatar
Been useing Devils Own Alky kit for a few months now on the whipple amd it works great . Priced very reasonable and the progressive controller works like a champ .
Silveradorst07
Dec 31, 2015 12:04 AM
greedygenius
Sep 3, 2015 06:51 AM
WICK3DxGATA
Aug 31, 2015 07:21 AM
tim wellington
Jul 31, 2015 03:28 PM
Deceptarado
Jul 8, 2015 05:24 PM
