need Meth kit
Old Jun 14, 2006 | 04:53 PM
NXRICKY's Avatar
Former Vendor
Originally Posted by jephs422
Is there a vendor here that I can pick up a meth kit from? Oh, and any suggestions on which one?
FJO, bad *** pump can install upstream down stream of the tank does not matter.
Stainless steel parts, pump is kick ***, no variable voltages. The nozzle to me is the only one of its kind. Take alook down load the software and check it out. Let me know if you need a tank to go with it.
http://www.fjoracing.com/products/waterinjection/
Ricky
Old Jun 14, 2006 | 05:17 PM
seadoo's Avatar
water injection washes the cyl. walls down... its the biggest NO NO
Old Jun 14, 2006 | 05:19 PM
jephs422's Avatar
??? what was this in reference to, so I am clear.
NXRICKY-
You have a PM
Old Jun 14, 2006 | 08:38 PM
hemidup's Avatar
Too much raw fuel will wash your cylinders walls of oil. Too much water will bog your engine.
Old Jun 14, 2006 | 08:47 PM
seadoo's Avatar
the link above my post... but I think that he is just refering to the cantainer
but, please check out alkycontrol.com and give them a call
Old Jun 14, 2006 | 09:59 PM
jephs422's Avatar
LOL, I should have known better than to ask a bunch of addicts what the best Meth was!!!! Okay, so I thought the Snow level 2 DID have a progressive controller. ALthough, the FJO software and controller seems bad ***. so does the Alkyconltrol. I think it's down to those two, AC or FJO. At this point I think it's going to be whatever is the chepaest between those two, cause I probably won't know the difference myself.
Old Jun 14, 2006 | 10:37 PM
kbracing96's Avatar
Let me throw another one at ya. I have see all the major meth injection units out there and I chose the Devils Own kit and love it! It's got the smallest progressive controller of any of the kits I've see, and it micro processor controlled. Easy to use too. Has just 2 ***** on the controller, a start psi and a full on psi. Plus it's MUCH cheaper then the others I have seen. You might want to check them out.
Old Jun 14, 2006 | 10:43 PM
04Denali's Avatar
Alky Control here
Custumer service is outstanding
Old Jun 14, 2006 | 11:05 PM
jephs422's Avatar
link?...
Old Jun 14, 2006 | 11:12 PM
kbracing96's Avatar
link?...
Do I have to do everything for ya
http://www.devilsownonline.com/index.php
