Need to know to wire twin walbros
Old Apr 16, 2011 | 07:17 AM
droppedchev's Avatar
Default Need to know to wire twin walbros
I'm looking to do the twin walbros I already have a 255 in there just wondering how the other fits in and how's it's wired I know it goes to a Hobbs switch but then where if someone can help me out
Old Apr 16, 2011 | 01:09 PM
Pocket's Avatar
Give this a shot
30 is red
87 is gry
86 grn
85 blk
87a not used
Old Apr 16, 2011 | 04:45 PM
Can't I just run one relay I already have a 255 in there just gotta add another one??
Old Apr 16, 2011 | 05:02 PM
MikeGyver's Avatar
Originally Posted by Pocket
Give this a shot
30 is red
87 is gry
86 grn
85 blk
87a not used
Doesn't the PCM ground the coil signal? If so, the 85s should go to a key-on positive instead.
Old Apr 16, 2011 | 05:57 PM
Someone make me one and I will buy it from u the whole relays and things confuse the crap out of me
Old Apr 16, 2011 | 08:38 PM
Pocket's Avatar
Fans and AC are ground. Fuel and IGN relays are IGN triggers. The hobbs switch turns the secondary pump into a dual trigger relay
Old Apr 16, 2011 | 08:57 PM
Pocket's Avatar
Can and should are two different things. You can run two electric fans off one relay, but two relays is ideal. You can run two pumps off relay but why not two? Are relays that expensive where you live?
Old Apr 17, 2011 | 08:04 AM
Someone make one that will plug in for my truck and I will buy it from u
Old Apr 20, 2011 | 12:05 PM
marovetsm's Avatar
How much fuel do you need? Maybe just swap out the Walbro you have with the new Aeromotive 340.
Old Apr 20, 2011 | 06:16 PM
Well I'm running 60lbs injectors but the pressure makes them 72s and I'm going for close to 700 hp
TrendSetter
Nov 26, 2018 07:18 AM
Chavette
Oct 28, 2015 07:33 PM
Tydriver
45
Oct 23, 2015 09:19 PM
Vortec350ss
Oct 10, 2015 09:11 PM
scooter k
Sep 16, 2015 10:32 PM
