Need Help w/ Procharged HO 502 '97 K2500
Old Jan 9, 2016 | 06:48 AM
  #61
tyoneal's Avatar
Default Further Studies with the Truck
Hello again:
Now past the holidays, I am taking the truck in to have the engine re-dynoed WITH the Boost being monitored through the pulls.
I have a couple of additional Dyno Sheets from the last run. These will be used as a base along with the first pull on Monday.
We will be having the boost monitored across the range to finish at 5500.
I am going to try and get the Torque convertor programed to be locked up as soon as possible and run the truck through all the gears starting as low in the RPM range as possible. I think it would be interesting just to see what the Data looks like.
Anyway, a 3.0 pulley will be place on it and a larger lower pulley if the SC isn't maxed out as low as possible in the RPM range.
I was informed that the D series SC's will max out at 8-9 psi, therefore I'm going to see if it can be made to hold a roughly flat line as early as possible to max out at 5500 or as close as possible.
I will get the gauges mounted in the truck as soon as I can.
Thanks,
Ty O'Neal
Attached Thumbnails Need Help w/ Procharged HO 502 '97 K2500-img_0372.jpg   Need Help w/ Procharged HO 502 '97 K2500-img_0374.jpg
Old Jan 9, 2016 | 11:39 AM
  #62
James B.'s Avatar
Looking foward to seeing that data
Old Jan 9, 2016 | 11:54 AM
  #63
1FastBrick's Avatar
Custm2500's Rude Friend
X2!
Old Apr 12, 2016 | 06:19 PM
  #64
tyoneal's Avatar
Hi Guys:
I had to re-build the computer last year and have a Video with boost gauge data, but it is on my backup drive. I will find it and get it transferred asap.
I'm really sorry about the delay.
Regards,
Ty O'Neal
Old Feb 23, 2017 | 09:34 PM
  #65
Sigurd's Avatar
Registered User
How do you get the gauges on the dash to work with aftermarket efi?
Old Feb 24, 2017 | 04:32 AM
  #66
tyoneal's Avatar
Default Update on my Truck
Here are some pictures of the engine being rebuilt to perform better. (Hopefully)
Any questions welcome.
Attached Thumbnails Need Help w/ Procharged HO 502 '97 K2500-img_2543.jpg   Need Help w/ Procharged HO 502 '97 K2500-img_2501.jpg   Need Help w/ Procharged HO 502 '97 K2500-img_2540.jpg   Need Help w/ Procharged HO 502 '97 K2500-img_2542.jpg   Need Help w/ Procharged HO 502 '97 K2500-img_2509.jpg
Need Help w/ Procharged HO 502 '97 K2500-img_9507.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_3765.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_1234.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_2500.jpg
Old Feb 24, 2017 | 04:47 AM
  #67
tyoneal's Avatar
Default Additional Pictures
Here are more:
Attached Thumbnails Need Help w/ Procharged HO 502 '97 K2500-img_4104.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_3877.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_5905.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_9112.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_6706.jpeg
Need Help w/ Procharged HO 502 '97 K2500-img_4958.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_8335.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_9339-2.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_5004.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_8872.jpeg
Old Feb 24, 2017 | 04:50 AM
  #68
tyoneal's Avatar
Default A few more
The rest:
Attached Thumbnails Need Help w/ Procharged HO 502 '97 K2500-img_2382.jpg   Need Help w/ Procharged HO 502 '97 K2500-img_2383.jpg   Need Help w/ Procharged HO 502 '97 K2500-img_3224.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_5976.jpeg   Need Help w/ Procharged HO 502 '97 K2500-img_2576.jpeg
Need Help w/ Procharged HO 502 '97 K2500-img_0870.jpeg
Old Feb 24, 2017 | 05:25 AM
  #69
tyoneal's Avatar
Default New Cam Card
Here are the SpecsI think this will be a much improved Item from Stock)
Attached Thumbnails Need Help w/ Procharged HO 502 '97 K2500-new-suburban-cam-card-specs.png
madmann26
Apr 29, 2020 09:17 AM
murderedSS
Sep 27, 2015 10:16 PM
MOBBN
Sep 22, 2015 08:07 PM
murderedSS
Sep 22, 2015 03:53 AM
Justin87gn
Sep 10, 2015 12:06 PM
