My Av+Radix on the DynoJet
Old Sep 2, 2005 | 08:03 PM
  #21
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by DamonCollins
thoughout...and above 4500 I was lock onto it
Just not a good idea...the pump is in the kit for a reason.....
Old Sep 2, 2005 | 08:05 PM
  #22
moregrip's Avatar
what a rush!
thoughout...and above 4500 I was locked onto it
Good, now stop, drive easy, wait for the pump, and re dyno. Do you have a boost gauge?
Old Sep 2, 2005 | 08:06 PM
  #23
BigBlackAv's Avatar
I understand...I want it in there also.
Old Sep 2, 2005 | 08:07 PM
  #24
BigBlackAv's Avatar
oh yeah...fuel pressure, boost and an EGT in the triple piller pod.
  #25
moregrip's Avatar
what a rush!
does your boost gauge read vaccum? if so, whats it read at idle?
Old Sep 2, 2005 | 08:11 PM
  #26
BigBlackAv's Avatar
yes...it is up and down...20-10...i'll pay closer attention to idle vacuum if you think it could clue me in...I had been watching it but I can't see any pattern to its movement.
Old Sep 2, 2005 | 08:16 PM
  #27
moregrip's Avatar
what a rush!
sounds like something isn't right, double check for leaks. A reading of 10 will cause problems, but 20 is excellent, so there is an issue.
Old Sep 2, 2005 | 08:27 PM
  #28
moregrip's Avatar
what a rush!
the high fluctuation in manifold vacuum can mean a vacuum leak or even improperly seated intake manifold gaskets, which to me, sounds like your idle issue.
Old Sep 2, 2005 | 08:28 PM
  #29
ranwalk's Avatar
Were the dyno runs made with the converter locked or unlocked?
Old Sep 3, 2005 | 10:09 AM
  #30
TurboGibbs's Avatar
My cam is basically what the trucker with 1* less lobe sep. I am still waiting to hear from the guy that was supposed to be tuning mine this weekend . Mine dies 95% of the time when I come to a stop or even push in the clutch slowing down for a turn. It is very aggrivating. Especially when I was supposed to have it tuned already but the guy won't call me back . Anyway, not to get off the subject, mine idles @14". I have to let it go through a few surge cycles before it will idle. Mine being a 4.8 is why I'm probably having a little more issues than he is.
