Muffler for my STS kit
Old Nov 26, 2005 | 07:37 PM
Scott Mills's Avatar
Default Muffler for my STS kit
What are some suggestions for a muffler for my STS kit? I was think of buying a 2 into 1 muffler and having it replace the y pipe in front of the turbo Hooker. Another option I was also thinking about is 2 short glasspacks in front of the turbo before the Y. I need to do something becasue it is too loud when towing.
Old Nov 26, 2005 | 08:24 PM
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
this is off topic some, but do you have any sound clips of you truck now?
Old Nov 26, 2005 | 08:28 PM
It isnt any louder than a mild performance exhaust, but when you put a load behind it it gets very loud.
Old Nov 26, 2005 | 08:34 PM
F8L Z71's Avatar
I used a Magnaflo muffler. You want a straight through type of muffler for the best flow for forced induction. I tried the 1ch Flowmaster as well and didn't like the sound as much and it felt like I lost a bit of power.
Old Nov 26, 2005 | 08:42 PM
Sounds like some straight through glass packs should work.
Old Nov 26, 2005 | 08:52 PM
F8L Z71's Avatar
Just make sure they are quality units so you keep as much packing in them in the long term or it's gonna end up sounding like *** when it all blows out LOL
Old Nov 26, 2005 | 09:38 PM
CHarris's Avatar
Are you talking about putting a muffler with packing before the STS turbo? I hope I'm misunderstanding... because that is a bad idea. I wouldn't put any muffler in front of a turbo. Every muffler I've ever seen had a little bit of junk inside of it from the welding/cutting /grinding of assembly that blows/burns out and in your case it would go straight into your turbo impeller.
I hope you meant that you wanted a muffler on the turbo exhaust.
Old Nov 26, 2005 | 09:48 PM
Ok, thats a good point about the packing blowing out I forgot about that. So are there any bad effects if I put a muffler after the turbo?
Old Nov 26, 2005 | 09:51 PM
CHarris's Avatar
Nothing much as long as it isn't restrictive.
Old Nov 26, 2005 | 10:15 PM
TG02Z71's Avatar
Keep the diameter of the through hole at least the same size as the turbo outlet. I did a 3" tailpipe and wish I would have done 3.5" or 4". I felt a small amount of spool up lost from the back pressure. I plan on putting on a resonator with a turn down on it in the spring or over winter.
A straight through muffler is good, just make sure it is straight through, not channeled or a multi baffled design.
Back pressure is bad for turbo spool up!!
