More boost for my Whipple
Old Oct 8, 2007 | 07:32 PM
scott2004's Avatar
Default More boost for my Whipple
Right now I'm at 5lbs with the stock pully on my 5.3 with the Whipple. Of course, now I want more. Is there a smaller pully I can get to up the boost a little? Who has them? Will I have any issues runinng say 7-9lbs on a stock bottom-end given I have a good tune, 42lb injectors, and meth?
Thanks,
Scott
Old Oct 8, 2007 | 07:34 PM
nightrunner's Avatar
Mr. Obvious
i dont see a problem with 8psi on stock bottom with a GOOD tune and meth.
Old Oct 8, 2007 | 08:01 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I think your trans will complain before your engine. I don't know anything about the pulley's for your setup though, sorry. Watch out, boost is addictive!
Old Oct 8, 2007 | 08:06 PM
Mr. Obvious
also i was thinking about an intercooled setup, id want some way to monitor the AFR via a wideband
Old Oct 8, 2007 | 08:23 PM
MikeGyver's Avatar
Originally Posted by scott2004
... Is there a smaller pully I can get to up the boost a little?...
Thanks,
Scott
Whipple is the only place to get pulleys that I know of. They make them in any size in 1/8 inch increments. I forgot the range that the guy told me, but I remember that they go ridiculously small. Each 1/8" smaller gives aboot 1 added psi.
Old Oct 8, 2007 | 08:25 PM
scott2004's Avatar
Sure is addictive. How much are you pushing through your 5.3? I started collecting parts for a forged 370.
I have a wideband and HPT for logging. I'll have to look into a intercooler setup for this.
Old Oct 8, 2007 | 08:27 PM
laynlow77's Avatar
there isnt an intercooled version out, youll have to make your own.
Old Oct 8, 2007 | 08:31 PM
scott2004's Avatar
Thanks. Is your motor stock except for the Whipple?
Old Oct 8, 2007 | 09:27 PM
MikeGyver's Avatar
Yeah, for now.
Old Oct 9, 2007 | 01:13 AM
91_bowtie's Avatar
and alot more heat
I was told that the 3.5" pulley is as small as they go.
