More boost for my Whipple
Old Oct 10, 2007 | 06:53 PM
  #21
scott2004's Avatar
I love mine so far.
Old Oct 10, 2007 | 07:05 PM
  #22
03sierraslt's Avatar
I wonder how much different the whipple pullies are from the KB's? I dont remember how the whipple pullies are setup... I just ordered a 3 1/8 for my KB.
Old Oct 10, 2007 | 10:53 PM
  #23
scott2004's Avatar
The KB pully I saw looks much smaller and only had 2 screws. My Whipple has 4. The KB I was looking at was pretty old though.
Old Oct 11, 2007 | 02:26 AM
  #24
James B.'s Avatar
The limitation on the single-belt 4.8/5.3 kit is that the pulley has to clear the billet front cover inside of it. There was a 2-belt 4.8/5.3/6.0 kit that used a standard-offset pulley. That kit allowed pulley sizes down to the smallest available. There are other factors limiting the smallest realistic pulley size: the redline input speed is 16,000 RPM. Also, a 6-rib belt just cannot grip a pulley any smaller than 2.5/8". These things take a LOT of power to spin up due to there being so much rapidly-rotating mass inside. (Keep in mind that at 16K input RPM the second rotor is doing over 26k RPM!)
I run a 2.5/8" pulley on a W140AX with A2W intercooler to a 383CID (6.3L) SBC. The crank pulley is 7.5" diameter, shift points set to 5600-5700RPM. It makes 8-9 psi depending on temperature. Every factor in this setup is maxed out. The 2.3L compressor really is too small and the 6-rib belt is too pathetic for what most of us want around here - especially with engine displacement larger than 6L. Anyone who can get a 3.3L unit with a huge A2W intercooler and 8 or even 10-rib drive running under a stock hood would be my hero.
Also, I used to pay $65 for pulleys. I guess that was the good ol' days.
Old Oct 11, 2007 | 02:24 PM
  #25
dc96819's Avatar
Some serious tractin there James B
So what kind of heads and cam you got going?
Old Oct 11, 2007 | 10:04 PM
  #26
James B.'s Avatar
Originally Posted by dc96819
...So what kind of heads and cam you got going?
Heads are Edelbrock E-Tec 200. They have 1.6" exhaust and 2.02" intake valves. Single spring plus dampeners setup. Supposedly they are good to 6500RPM but boost reduces that limit due to pressure against the back side of the intake valves somewhat. The cam is a Crower 00401LM (LM for late-model meaning stepped nose and smaller bolt circle compatibe with stock thrust plate.) Cam specs are 214/220 on a 114 LSA with 0.316" intake and 0.332 exhaust which works out to 0.506" intake and 0.531" exhaust with 1.6:1 rockers. It works great but this is not a "fuel economy" setup.
lxcoupe
Sep 22, 2015 02:50 PM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
