max out a whipple???????
I have no idea....
We were suprised.. I mean the boost gauge coulda been reading Inaccuratly..
But Justin (yellowsierra) have a I guess 2.75 or somewhere around there pulley made and he was running ?13-14? on his 5.7.. So I was guessing around 15-17 on a 5.3 or 4.8
Boost isn't an accurate meaure of maxing out a blower or making power. Boost is restriction. I could make 15psi with a whipple on a 4.8 if it had tiny heads, valves, stock manifolds and exhaust. Will that make more power than a whipple (with the same pulley), nice flowing heads and exhaust, and a properly spec'd cam. No, and the latter setup will result in less boost.
If you're concerned about maxing out your whipple then step up to the 3300AX.
Definently..... You will probably have to get the pulley made for that..
Contact "Ironworker" he bought my whipple from me.... He has a pulley that Yellowsierra had made.... It should be good for that!!
whipple's are only made for 16k rpm....at 12 lbs of boost you actually making all the boost you can. A buddy of mine and fellow ls1tech'r ranwalk is maxing out his whipple making 21k rpm....thats w/ a custom pulley so yes you can max out a whipple
Originally Posted by slamedboosted&shaved
how much boost is 21k rpm
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
2plus2
Sep 13, 2015 07:17 PM
