Radix IAT
Been monitoring my IAT's on the new Radix setup with EFI Live.
Outside temp about 80*
I am seeing IAT from 118* to 135* Cruising the IAT dropped to 118, and boosting they were about 130*
First, I did a search and came up with everyting from 90*-190* I want to know if my monitored IAT's are normal? If not, where should it be? I want a baseline on my truck for future monitoring.
On the good side, I saw no KR and my LTFT's were all within the -5 to 5(actual -3 to +4, approx -1 while cruising) range. I am extremely happy so far with the Stock Radix tune.
In 100 degree weather my IAT's are around 140 or 150 in stop and go traffic. I have seen them get as high as 205 on a long WOT pull. Last week at the track I left the motor running and my efans running on high in the staging lanes and I could get the IAT's to drop to 117 before my run, they'd be at 140 or so by the end of the run. That was 90 degree weather.
I just installed the electronics portion of my Alkycontrol kit...I will post up some results when I get the rest of the system in and running.
sounds normal to me also.
yep sounds normal...i was logging 2 days ago and was getting 110 deg going down the hiway in 95 deg weather...got on it as if to make a pass and it went to 140 and started going down from there...
TAPyvehc93
Sep 17, 2015 10:10 AM
