max out a whipple???????
Old Sep 22, 2005 | 05:11 PM
slamedboosted&shaved's Avatar
Default max out a whipple???????
how much boost can a whipple put out??
Old Sep 22, 2005 | 08:51 PM
CAMMIN03''s Avatar
Banned
Ive heard up to 16-17psi....
but.... some people will disagree..
I was running 11-12psi and had 2 more pullies to go!!
Old Sep 22, 2005 | 09:27 PM
how were you running so much boost? That's odd. The smallest pulley will only get you 10ish. hmmm.
Old Sep 22, 2005 | 10:18 PM
CAMMIN03''s Avatar
Banned
I have no idea....
We were suprised.. I mean the boost gauge coulda been reading Inaccuratly..
But Justin (yellowsierra) have a I guess 2.75 or somewhere around there pulley made and he was running ?13-14? on his 5.7.. So I was guessing around 15-17 on a 5.3 or 4.8
Old Sep 22, 2005 | 11:54 PM
vanillagorilla's Avatar
Boost isn't an accurate meaure of maxing out a blower or making power. Boost is restriction. I could make 15psi with a whipple on a 4.8 if it had tiny heads, valves, stock manifolds and exhaust. Will that make more power than a whipple (with the same pulley), nice flowing heads and exhaust, and a properly spec'd cam. No, and the latter setup will result in less boost.
If you're concerned about maxing out your whipple then step up to the 3300AX.
Old Sep 23, 2005 | 05:54 AM
well i was wondering becasue i'm about to put some 6.0 heads on my 5.3 and i was told to run about 15psi and i was wondering if the blowwer could handle it
Old Sep 23, 2005 | 10:40 AM
CAMMIN03''s Avatar
Banned
Definently..... You will probably have to get the pulley made for that..
Contact "Ironworker" he bought my whipple from me.... He has a pulley that Yellowsierra had made.... It should be good for that!!
Old Sep 24, 2005 | 12:17 PM
NightmareTBSS's Avatar
whipple's are only made for 16k rpm....at 12 lbs of boost you actually making all the boost you can. A buddy of mine and fellow ls1tech'r ranwalk is maxing out his whipple making 21k rpm....thats w/ a custom pulley so yes you can max out a whipple
Old Sep 24, 2005 | 01:42 PM
how much boost is 21k rpm
Old Sep 24, 2005 | 03:45 PM
MikeGyver's Avatar
And if he had to make a pulley to do that, did he make an even smaller one that did not increase the boost? How do you know he was maxing it out?
Lthompson
Oct 2, 2015 12:45 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
2plus2
Sep 13, 2015 07:17 PM
