Magnacharger belt wrap solution
Using the original Magnacharger snout support and a design originally pioneered by Gadgetized, I decided to improve upon his idea of adding an idler pulley below the snout of the MP112 to increase belt wrap. I am no machinist but I know enough to be dangerous so with a Bridgeport and a lathe I made a new snout support with pulley mount. This setup is with 2.9" pulley but I am sure could be modified with smaller idler for larger supercharger pulleys. I also added a jack-screw to preload the snout because of the added load.
Looks good man, I remember seeing Gagetized's setup like that. It looks like it should be effective and I cannot see where it would cause any issues. Thanks for sharing. The jack screw, is it setup to apply pressure on the main bracket so that the two bolts are not taking all the load? Do you have any pics from the rear?
thompson
Dec 27, 2017 06:48 AM
