Magnacharger belt wrap solution
Old Mar 30, 2013 | 07:41 PM
Cakes's Avatar
Default Magnacharger belt wrap solution
Using the original Magnacharger snout support and a design originally pioneered by Gadgetized, I decided to improve upon his idea of adding an idler pulley below the snout of the MP112 to increase belt wrap. I am no machinist but I know enough to be dangerous so with a Bridgeport and a lathe I made a new snout support with pulley mount. This setup is with 2.9" pulley but I am sure could be modified with smaller idler for larger supercharger pulleys. I also added a jack-screw to preload the snout because of the added load.
Old Mar 30, 2013 | 07:50 PM
03sierraslt's Avatar
Looks good man, I remember seeing Gagetized's setup like that. It looks like it should be effective and I cannot see where it would cause any issues. Thanks for sharing. The jack screw, is it setup to apply pressure on the main bracket so that the two bolts are not taking all the load? Do you have any pics from the rear?
Old Mar 30, 2013 | 07:57 PM
TIM Z's Avatar
11 sec. Truck Mod
Wow that turned out good !
Looks like about 320* of wrap at least ! Nice. !
Old Mar 31, 2013 | 07:00 AM
Cakes's Avatar
The jack screw pushes against the main pulley bracket bolted to the front of the engine. I will try and get some pictures of the rear today.
Old Apr 1, 2013 | 09:14 AM
Vortec350ss's Avatar
That looks awesome. I would imagine it makes a pretty decent difference!
Old Feb 20, 2016 | 10:27 AM
lt1s10's Avatar
In the way back machine... BUMP this thread for some results!
thompson
Dec 27, 2017 06:48 AM
Avalanche2002
Nov 30, 2015 07:31 AM
Wolftrk99
Oct 2, 2015 08:17 AM
Chevy305
Sep 28, 2015 09:21 PM
murderedSS
Sep 27, 2015 10:16 PM
