MAGGIE guys what stalls are you using??
Old Mar 2, 2007 | 09:36 PM
NORCAL TBSS's Avatar
Restricted User
Default MAGGIE guys what stalls are you using??
just seeing stalls you guys are using. tbss with 4.10 gears thinking about yank sc2800 or down to 2600??
so what are you guys using and what gears do you have in your trucks??
Old Mar 2, 2007 | 09:56 PM
I run a 3000 stall Vigilante with a 3disc lockup clutch with my current 4L80E.I ran a Yank tt3000 when I was running a 4L60E.
Old Mar 2, 2007 | 10:13 PM
Crash Dummy's Avatar
Former Moderator :(
2600-2800 is what most are using , going any higher is just throwing all that down low torque away. Yank makes a mechanicle lock up 2600 for the Magna Charger
cyazo6's Avatar
I run a Vigilante 2600 rpm 3 disk as suggested by FLT.
Old Mar 2, 2007 | 10:21 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yank SC2800 just loose enough not too loose.
Old Mar 3, 2007 | 12:57 AM
Restricted User
yah im going with the sc series by yank. what gears are you guys running?? i have 4.10s so i think 2600 might be the way 2800 at most.
Old Mar 3, 2007 | 01:55 AM
Mr. Sandog's Avatar
You're leaving out the fact that you have 30" tires, which is very important info. Having 4.10's with 30" tires is like having 4.56's with 32" tires.
I don't think you'll want to go more than 2600, otherwise you'll be throwing the best part of the roots away like Dummy says. Then you may as well have gotten a centrifugal or a turbo.
Old Mar 3, 2007 | 02:11 AM
Restricted User
ill be runnign 275 40 17 drag rads which is like 5.00 gear ratio
Old Mar 3, 2007 | 09:16 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Me to. 4.10 gears
Old Mar 3, 2007 | 09:35 AM
Restricted User
so with 4.10 gears the 2600 is ok? or would you go 2800
