Maggie 112 78mm to 90mm?
Swaping a LQ4 w/Comp 265 highlift cam 4l80e into a 55 chevy and I'm a little up in the air on PCM TB combo. I have an 04 PCM/4l80 harness but no TAC/pedal (which is cheap and easy to find). I also have the stock 75-78mm DBW TB. So the cheapest/easiest is to run the stock tb with a 3 bolt to 4 bolt (maggie has 90mm jtube). How much power will I be sacificing with the smaller tb? This route I can pick up a 90mm car (which one) or 87mm truck (unsure of what works right yet) and an x-Link which as far as I can tell is required.
Anyone done dyno comparisons on upsixing throttle body on 5.3 or 6.0 w/m112 preferably back to back?
mines a complete driver with a 350/350 combo in it now and I wont do the swap until I have every part and I'm 100% ready to swap in. My car has a 3rd nova subframe so nothing that applies to tri 5 chevys applies to mine.
Ls1 with my set up right at 30whp. It really made a difference. I've heard the 102's will get up to 35whp.
Ls1 with a mild cam, 90mm tb headers, maggie and meth 556whp 548wtq. 13 psi. Finally got the 3.0 wheel on it last week.. IW 8rib over drive set up to.
