MAF sensor blew apart
Old May 29, 2013 | 09:29 PM
Ferocity02's Avatar
Default MAF sensor blew apart
Was logging some data on the way home today and got into it in 2nd and shifted into 3rd at 6100RPM and ~6psi. Got back in it about a second later and the power was low and hesitating, so I let off the gas quickly put in the clutch and and the engine died. Thought for sure I blew her up, but I got out and didn't see any oil or smoke. Looked under the hood and saw the MAF had blown apart. The outlet lip had sheared clean off from the rest. I was only two blocks from home so I limped it back.
Has this happened to anyone else? My only explanation is that during the shift the pressure in the cold side was too great and it blew apart the MAF. The BOV is working just fine.
I guess this is a good time to go SD and 2 bar COS
File Type: efi
Old May 29, 2013 | 10:16 PM
GMCtrk's Avatar
I need to get mine out of there ASAP. Mines held together up to a max of 8.7 psi thus far but I don't want to chance it. Truck has been on a flatbed twice since getting the turbo on (sucks)
Old May 29, 2013 | 10:22 PM
Mangled03gmc's Avatar
Baltimore Whore
I guess I have been EXTREMELY lucky then. I have manged to beat this **** out of my stock tensioner( only had to replace it 1 time) and never had the MAF blow apart, been boosted for the past 5 years from6-12lbs.
Old May 30, 2013 | 12:37 AM
AndysC3's Avatar
Mines been on a flatbed twice as well. Once when the trans went out and a starter. Good thing yours is an easy fix. If you need a new one for the time being send me a pm. I still have my stock one.
Old May 30, 2013 | 08:20 AM
nonnieselman's Avatar
Yea perfect time to go SD!
Old May 30, 2013 | 11:01 AM
Ferocity02's Avatar
Couple pics. It was a clean break. Looks like it is maybe glued at the joint from the factory. I superglued it back together and it will probably be even stronger now, or it will break somewhere else.
Old May 30, 2013 | 11:21 AM
TrickTurbo's Avatar
Truck Sponsor
It's happens. If the maf is under any tension it breaks pretty easy.
Old May 30, 2013 | 11:39 AM
Hunter04's Avatar
do i have to run a 2 bar if im gonna boost?
Old May 30, 2013 | 11:48 AM
Pretty much would be a good idea
Old May 30, 2013 | 11:49 AM
Ferocity02's Avatar
I'm still using a 1bar MAP and stock OS. A 2bar MAP and COS will give you better control in boost. Seeing that my MAF wants me to go speed density, I'll make the switch to 2bar COS here soon.
