Low Mount TTurbo
Old Mar 23, 2011 | 10:26 PM
v502's Avatar
Default Low Mount TTurbo
Hey Guys I looking for headers options for twin turbo silverado build?
Basically what am looking for is ideas or pics for something similar to stock headers but tubular or logs style?
Thanks
Old Mar 24, 2011 | 12:45 AM
v502's Avatar
Bump 30 views and nothing !!
Old Mar 24, 2011 | 01:01 AM
rhinosarge's Avatar
sexy!! how about that
Old Mar 24, 2011 | 02:06 AM
pewterliftedz's Avatar
if your wanting a TT low mount setup, why not run longtubes?
Old Mar 24, 2011 | 05:08 AM
chevybowtie's Avatar
Here is mine. Stainless steel log style. Can't take credit though. Someone else built them.
Old Mar 24, 2011 | 08:25 AM
FarmTruc's Avatar
Performance Trucks Sponsor
Pretty simple to build log headers, here's a couple pics to get you started.
Attached Thumbnails Low Mount TTurbo-img_2443.jpg   Low Mount TTurbo-img_2447.jpg   Low Mount TTurbo-img_2449.jpg
Old Mar 24, 2011 | 08:33 AM
Rick_Vor's Avatar
For a low mount, just use OEM truck manifolds. You could also try some C5 or Camaro OEM's and see if they they will fit. They might open up a little more space by moving the outlet flange foward.
Old Mar 24, 2011 | 05:01 PM
TrickTurbo's Avatar
Truck Sponsor
Truck manifolds will work well. Can hang the turbos right off them, just suck them up as tight as possible. You might not need an oil pump, to return the used oil, and can use gravity drains.
Old Mar 24, 2011 | 07:22 PM
v502's Avatar
Good looking setup. Do you got any closer pics ? Thanks
Thanks for the pics very helpful. Any noticeable difference between stock cast or cast header ?
I would like to go with stock headers but I dont know if flow enough I be pushing somewhere around 1500hp.
I got both 5.3 and 6.2 stock headers laying around I try them both before I start.
I check on the truck headers and how they fit before i go with the log headers.I think they be too low I will run dual scavenge pumps just for the piece of mind. Thanks
Old Mar 25, 2011 | 10:18 AM
charcold-bowtie's Avatar
https://ls1tech.com/forums/forced-in...202-80mph.html
Truck mannys FTW
