Lost boost after intake and 80e swap
Old Jan 3, 2013 | 11:34 AM
  #21
smokeshow's Avatar
Mod with training wheels
It sounds like the new intercooler is more restrictive. Actual VE has dropped post-intercooler because of the restriction so there is less boost after the intercooler, hence the added richness. On that same note, you may also be seeing better IATs because the air is being forced through a more efficient intercooler.
Either way, this isn't a case in which you can just move the boost reference like you could for a turbo. You'll need to retune for it.
Old Jan 3, 2013 | 11:55 AM
  #22
AndysC3's Avatar
So I'm going to need a better intercooler. Only thing is there's not much room where I have it now
Old Jan 3, 2013 | 12:01 PM
  #23
sharpshooter's Avatar
Also a broken bypass valve could cause this same senerio.
Old Jan 3, 2013 | 12:20 PM
  #24
03sierraslt's Avatar
If VE was tuned correctly before then AFR should not be that rich if he is 2bar. I can lower my boost and maintain the proper AFR because now you are just using a lower section of your VE table.
Old Jan 3, 2013 | 12:32 PM
  #25
AndysC3's Avatar
I only have one section of the boost ve table tuned. And it was for 9-10 psi.
Old Jan 3, 2013 | 12:33 PM
  #26
Well that explains it. Lol
Old Jan 5, 2013 | 11:53 PM
  #27
AndysC3's Avatar
turns out that the wideband sensor was bad. I replaced it and AFR is spot on at 11.8-12.2
Old Jan 6, 2013 | 12:07 AM
  #28
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you went from the ProCharger 3 core intercooler to an eBay unit at the dimensions you listed, you downgraded yourself.
Old Jan 6, 2013 | 01:15 AM
  #29
AndysC3's Avatar
Well the 3 core iat went from 100-170* in one run. The new setup went from 70-77 in the same run
Old Jan 6, 2013 | 02:31 AM
  #30
Mounting position improvement IMO.
