Lost boost after intake and 80e swap
Old Jan 3, 2013 | 01:11 AM
AndysC3's Avatar
Default Lost boost after intake and 80e swap
Before my 60e broke I would see about 9-10 psi at 6200. Now I have a fmic, and 4" intake tube, a larger intake filter, and the Recirculation valve is vented to atmosphere. And I'm only getting 7-8 psi and is running bed rich. I'm thinking its the recirculation valve bleeding boost. Any other ideas?
Old Jan 3, 2013 | 04:24 AM
03sierraslt's Avatar
If anything the 80e will load it more helping boost a bit due to the gear ratios. Something must be leaking.
Old Jan 3, 2013 | 05:09 AM
AndysC3's Avatar
I may swap the old filter back on and have the recirc valve go back into the pre procharger filter and see if that helps
Old Jan 3, 2013 | 05:39 AM
That would be a good place to start.
Old Jan 3, 2013 | 07:49 AM
AndysC3's Avatar
I also made a boost leak tester. I just need an air compressor and need to find a way to seal the exhaust tip.
Old Jan 3, 2013 | 08:11 AM
custom 68's Avatar
looking at your first post here you did change alot, I am sure the tranny change didnt make a difference. looks like you added a FMIC and different intake system. I would look at all your new connections.
Old Jan 3, 2013 | 08:26 AM
Good point, I couldn't remember what all was changed. Andy if you went to a larger intercooler that could be part of it.
Old Jan 3, 2013 | 08:34 AM
chevyboy.520's Avatar
You fmic and new intake flow better, which results in less boost ( less restriction) but more overall power.
Old Jan 3, 2013 | 08:43 AM
A better flowing intake pre blower can raise boost, better flowing piping and intercooler after the blower can lower boost if flow is increased.
Old Jan 3, 2013 | 08:51 AM
Mangled03gmc's Avatar
Baltimore Whore
This, but did you do the intake manifold, FMIC at the same time? The truck prob is just as fast just less boost. Boost is a restriction number as stated.
