Lost boost after intake and 80e swap
Old Jan 6, 2013 | 04:00 AM
  #31
AndysC3's Avatar
Yea, I'll have to save up for a nicer one, but I'm not sure how much bigger I can go with where its mounted. I may save up and do a water/air intercooler.
Old Jan 6, 2013 | 05:02 AM
  #32
03sierraslt's Avatar
Originally Posted by AndysC3
turns out that the wideband sensor was bad. I replaced it and AFR is spot on at 11.8-12.2
Add a bit more fuel.
Old Jan 30, 2013 | 11:28 PM
  #33
AndysC3's Avatar
Got afr to a steady 11.4-11.6. 15* of timing the 3.6" pulley and only getting 9.5-10psi at 6500. So I'm guessing I need a new intercooler. What is the biggest one I can fit behind the grill? I can fit a 3" maybe a 3.5" core where the current one is but no way will a 4" core will fit. I found a 31x12x4 on eBay. Will something like that work. I want more boost. Lol
Old Jan 30, 2013 | 11:45 PM
  #34
smokeshow's Avatar
Mod with training wheels
Just as an experiment....pull the IC out and stuff a straight 3" pipe in there, see how the boost changes.
Old Jan 31, 2013 | 12:15 AM
  #35
AndysC3's Avatar
I may try that once the meth it hooked up. That way I have something to cool the incoming air. It's almost done. Just have to wire everything in and test it. Hardest part is going to find an ignition on switch. Do you know of any place in town have about 27" of 3" pipe?
Old Jan 31, 2013 | 01:23 AM
  #36
smokeshow's Avatar
I could cut you one. But i have a giant length of silicone coupler you can borrow, would be easier lol
Old Jan 31, 2013 | 01:26 AM
  #37
AndysC3's Avatar
That would be great. When would be a good time to pick it up?
Old Jan 31, 2013 | 01:30 AM
  #38
smokeshow's Avatar
Whenever. Long as you give it back.
Old Jan 31, 2013 | 01:34 AM
  #39
AndysC3's Avatar
Lol, I will. Are you free tomorrow?
Old Jan 31, 2013 | 02:10 AM
  #40
smokeshow's Avatar
I am busy tomorrow, but you can stop by in the evening to pick it up. It is 36" long end to end.
