Large intercooler for Maggie's. Is there room??
Old Jul 21, 2010 | 09:10 PM
  #21
DrX's Avatar
DrX
The TVS units have a little room to go up. The IC core is already pretty deep into the tub though. A comparison of adding a 3/4" spacer vs adding 3/4" to the IC core would be interesting.
On the Radix units yould have to cut the runners out of the tub to gain any space- basically converting it into a TVS style tub.
Old Jul 21, 2010 | 09:54 PM
  #22
SuperchargedSS's Avatar
I had clearance issues with my 122s Jtube coming within 1/4" or so of the firewall, cant imagine going any higher than that. TVS is a whole 'nother story.
Old Jul 21, 2010 | 10:24 PM
  #23
supersub's Avatar
It's a 1" spacer, and yes it raises the intercooler off the floor of the tub! and 100 ft of torque i would say! Just my guess of coarse, my two dynos sessions were quite revealing. without my spacer... 590rwhp on a dynojet, with it.... 714rwhp on a mustang.
increasing the plenum volume does wonders to bigger cube combo's,heat isolation is a plus and lastly increased fuel injectors provide the much needed fuel for those little extra ponies....
I have a 1/2" of cowl clearance left. for those that have the room should def try to take advantage of it.
Old Jul 21, 2010 | 10:32 PM
  #24
supersub's Avatar
What makes the roush kits interesting is how they create space between the rotor and the intercooler, the that extra space between the two allow more surface area contact on the intercooler vs ours being placed right on it.
Imagine a template using spray paint paint goes on nice and tight, creating a confined image, minimal surface contact. Now take that same template and raise it up an inch or two, that same template creates a larger image, more surface contact occurs in theory using more intercooler surface.
cant do that on a jack shaft version due to seperate mounting of shaft and rotor group.
could do that on a radix though, if you had the cowl room
My .02
Old Jul 21, 2010 | 10:39 PM
  #25
supersub's Avatar
I just finished a 112 jackshaft version froma TBSS kit using a 1" spacer, overdriving the rear and adding a 102mm trottlebody this little baby should rock
I will get some pic's up of how tight this stuff really is.
Old Jul 21, 2010 | 10:53 PM
  #26
TX Tahoe Z71's Avatar
The only change between pulls was the spacer?!?! That's crazy... I need to start doing my homework and get this going on mine!
Old Jul 22, 2010 | 06:20 AM
  #27
blownss06's Avatar
124hp with just a spacer. I will pm you for more info. Either way i am looking to lower my iat.
Old Jul 22, 2010 | 09:40 AM
  #28
OnyxSilveradoSS's Avatar
HI, Ray
I did not want to say your name and have thousands of guys calling you about the spacers...but if you are getting the #'s it is gonna be a popular mod
Old Jul 22, 2010 | 09:51 AM
  #29
Rat Raceway's Avatar
Ray has one heading my way too!
I would love to stuff a bigger intercooler in tube, wile there...
HOOK US UP!
Old Jul 22, 2010 | 10:40 AM
  #30
OLD NO.7 Avalanche's Avatar
This Heatsoak is a HUGE problem in my AV/6.0L.I'm in New York and I still get High IAT's.I even went so far as Buying a second IC just to add volume to make up for a small IC.
