l92 heads and boost??? are 317's better?
From: Where our street cars are faster than your racecars..Mississippi
say if i was to go with a stock l92 heads on my 408ci (-22cc pistons and ls9 gaskets) what kinda boost could i run before they start trying to lift?
i have 317's not and i was told you can't run the boost on the l92 that you can with a 317's because of the l92 deck being thinner than the already thin 317's??
i would like to make as much power as possible but not pushing water every time...lol
the main thing is... are the l92's as-cast heads worth the money or should i stick with my 317's untill i can afford a head such as the trick-flo 235cc?
My shop just wanted to do a pocket port and call it a day but I figured I might as well get them Stage 2. The intake side flows good but the exhaust side leaves a lot on the table.
9 Second Truck Club
Are the L92's indeede thiner? Has anyone actually measured one? I saw one down at the stealership the other day, and it looked to be similar thickness to the 317.... Yes I wen't mid 9's with 317's but they flow withen 3 cfm of the trick flow 220's I have sitting here... I doubt you will come anywhere close to the same power per lb of boost with a stock unported 317. The L92's, on that 408, 91mm will make way more power at lower boost than the stock 317's, and probably even ported 317's...
you cost me TOO much money
but thanks for ALWAYS helpin
