Kenne Bell intercooler is in!
Old Jun 15, 2006 | 03:59 PM
  #31
03sierraslt's Avatar
How did you kill the straight silicone pieces? I am going with t bolt clamps right from the beginning. Getting everything from TRT
Old Jun 15, 2006 | 08:01 PM
  #32
The clamps started to deform the silicone couplers and every day I had to re tighten for fear that the piping will come apart. Eventually they ripped. The 4 plys din not loose any torque.
Old Jun 15, 2006 | 09:43 PM
  #33
I just order all my stuff from Billy, got all t-bolts, and will only be using one silicone elbow. With the size of the elbow and having the piping in it there is no way for it to physically colapse on mine so.... hopefully all is good. Just waiting on the parts now.
Old Jun 20, 2006 | 12:13 AM
  #34
PAT, sounds like you are on track! Have fun, you will not regret. You should get some "before" logs of your IAT's. You will be horrified when you see 200f. This has been a very necessary mod.
cheer
Old Jun 20, 2006 | 01:07 AM
  #35
gmcC3syclone's Avatar
looks good ,ive been looking into a I/C right now ive just been using the meth kit but would like to have one for extra security and cooling, just added a 50 shot for a little more cooling and power,i also just added a carb manifold having a little difficulty connecting from the custom elbow to the kennebell im hopeing ill be able to fire her up tomm so i can get her dynoed asap
Old Jun 20, 2006 | 01:38 PM
  #36
Whippled 496's Avatar
So let me ask again...LOL...cause it got lost in some discussion a few posts back.
-Did you notice a definate SOTP difference after the intercooler was on?
-Did you make any timing/fuel changes before you noticed any difference?
-What type of gain are you expecting to see as far as E.T. goes? 1/2 a
half a second or less?
-Did the A/F change after the I/C went on?
Old Jun 20, 2006 | 09:28 PM
  #37
Linda, please see response below.
Yes It pulls very hard at the start. I now launch in 4wd.
The PCM self adjusted to the max of 18 degrees on the high octane table. before it was 13-15 degrees depending on the IATs.
half a second or less? Im definitely banking on a high 12, I will know in 3 weeks when I go to the track. 0 to 60 is under 5 seconds. Previously 5.5
-Did the A/F change after the I/C went on?[/QUOTE]
Yes, Slight adjustment made to the PE table.
Hope that helps. Any luck with your setup.
Old Jun 21, 2006 | 05:33 AM
  #38
Man, sounds like some real nice improvements there, thats fantastic. I am moving along with mine, the elbow collapsing thing slowed me down a little. I have 5 cast aluminum elbows coming in today. Two of which will be welded onto my flanges (intake inlet and blower outlet), the other three will replace the 3 silicone ones already in the circuit. I should have them welded up tomorrow and installed Friday/Saturday. This sucker has been 3 weeks getting done.......im getting really antsy to get it on the road again. Can't wait to feel the difference. I hope i dont have any problems welding the cast aluminum...i have read its more difficult to weld than regular plate aluminum. Where i bought it from, It specifically said great for welding....so we will see.
Old Jun 21, 2006 | 05:56 AM
  #39
Sounds like a nice setup. Make sure you have at least one hump hose on each of the pipes so there is dampening from the engine to the chassis mounted intercooler.
Good Luck and keep us posted.
Old Jul 10, 2007 | 01:35 PM
  #40
91_bowtie's Avatar
any updates?
Did you use a KB intercooler or get one off ebay? I plan on fabbing one up for my whipple in the next couple months.
