Intercooler Questions
Old Dec 26, 2005 | 02:54 PM
  #21
03sierraslt's Avatar
Scott Mills- If you dont mind me asking, what did that setup cost you? And where can I find more info on the intercooler you used?
Old Dec 26, 2005 | 02:55 PM
  #22
What type of pump are you using for the intercooler, Brand specs that type of stuff? Thanks
Old Dec 26, 2005 | 03:04 PM
  #23
Scott Mills's Avatar
I bought the Intercooler off ebay XSPower , it was $299. I also had to get a few different elbows and connectors (Ebay as well) they ran about $60. The Pump was a Syclone replacement $125. And the heat exchanger was off of Ebay as well, a used Lightning heat exchanger $79.
Old Dec 26, 2005 | 03:11 PM
  #24
JOHN1L40's Avatar
Not sure if this is an option for you. I saw about a 30 deg drop with the IC install. The meth is what really drops it. I went from 130 deg to 95 deg full boost run on a 90 deg california day. This is with the meth and IC.
Attached Thumbnails Intercooler Questions-2004_1105image0001-2-.jpg   Intercooler Questions-2004_1213image0002-2-.jpg   Intercooler Questions-2004_1213image0004-2-.jpg   Intercooler Questions-2005_0816image0001-2-.jpg
Old Dec 26, 2005 | 04:57 PM
  #25
Scott Mills- Do you happen to have any before and after IAT readings? Just wondering how much the drop was? This may work for me as well, I will have to look at the truck closer and see if maybe relocating the battery and putting it where the battery was would work.
Old Dec 26, 2005 | 05:11 PM
  #26
I dont have all of the measurements handy but I wonder if this intercooler will allow me to mount infront without cutting the supports?
http://www.superchargersonline.com/p...ber=ICE-IC30-C
Old Dec 26, 2005 | 05:17 PM
  #27
I believe the OBX intercoolers are 31" over all lengh vs. 25" On the one above.
Old Dec 26, 2005 | 07:19 PM
  #28
Well I don't have any direct comparisons, but earlier this year in Oct pre intercooler I was seeing temps as high as 167 degrees. Now in Dec the highest I have seen is 100 degrees. The ambient temp in Oct was much higher than in Dec so it is hard to tell what the change was.
Old Dec 26, 2005 | 07:32 PM
  #29
I need to do some research to find out if the ICEVEX intercooler will work without cutting the supports.
  #30
Then I just have to find a good means to do the piping.
