Intercooler Fans
Old May 28, 2006 | 09:08 PM
kbracing96's Avatar
Originally Posted by Lord Aries
Thats pretty sweet, I'll take a look at it... They do make a dif in the intake temps even when not in boost because the intercooler gets heated up by the surrounding air... Also, if you let it get hot then turn them on, it takes a minute to get the cooler temps down...
The intercooler is always going to be around ambient temp. The turbo isn't making any real heat until you start compressing the air, (boost) so you only really need the fans on to pull air though the intercooler when your in boost to cool the compressed air.
The way your intercooler is mounted, you get very little air flow though it. Turning the fans on only when you are in boost will pull air though it when you need it.
Also, it you put a 2" strip of plastic and mounted it vertical, sticking down at the back of the cooler, it would force a LOT of air though the cooler when your cruising down the road.
Old May 28, 2006 | 09:24 PM
03lowriderss's Avatar
KB is right make an intercooler "spoiler" to go with your setup
Old May 28, 2006 | 09:43 PM
ranwalk's Avatar
Originally Posted by Hydramatic
Anyone think of fabbing up a flap to mount on the intercooler to force air across the fins, ala 3rd gen Firebird?
Thats how the Procharger intercooler mounts also, but it has about a 3 inch strip that runs across the back of it to scoop up the air so to speak. I like the fan idea and have seen it on a couple of other trucks too. I wouldnt worry about a pressure switch. I would however look into tapping the power wire into a 12 volt ignition source. That way they would just come on whenever you start the truck. Wouldnt have to worry about anything other than driving it and hauling ***
I will probably end up adding some fans to mine as well.
Old May 28, 2006 | 10:22 PM
PappyDan's Avatar
Tribe Shaman
watching those two guys on muscle car on spike not too lone ago,
he formed a peace of sheet metal to work as a full shroud for a radiator with a single fan.
looked like a good idea to do to the intercooler, one single fan that can pull enough cfm's
through the intercooler to keep it the temps down.
my core is 24 x 12 so one 12" fan should be enough to do the job.
Old May 29, 2006 | 09:04 AM
Lord Aries's Avatar
Well, i like to play off road from time to time, thats the other reason for the on/off switch, have to kill them for water crossing and water holes.
Any one got pics of this spoiler thingy?
Old May 29, 2006 | 10:25 AM
kbracing96's Avatar
Here's an example, using my mad paint skills . You could even make it out of some clear acrylic from Home Depot and you would hardly even notice it. You will be surprised at how much a 2-3 inch air dam right there will improve air flow though the intercooler.
Old May 29, 2006 | 02:37 PM
Lord Aries's Avatar
Hhmmm... I might try that, i could always use 3M Tape so it could break aways if needed...
Old May 29, 2006 | 06:09 PM
ranwalk's Avatar
Here are couple of pics of the Procharger intercooler
$A_Money$81
Mar 27, 2023 10:25 AM
CD82
Oct 23, 2015 07:32 AM
turbo6c3
Oct 5, 2015 06:11 PM
Wrecker 426
Sep 30, 2015 09:39 PM
old motorhead
Sep 29, 2015 08:22 PM
