Intercooled sidemount setups
Old Oct 24, 2010 | 05:25 PM
Pocket's Avatar
Default Intercooled sidemount setups
Whos put a front mount intercooler in with a side mount blower setup like this regardless of blower size/brand:
How does it run with the TB mounted before the blower? Im concerned the extra plenum volume will severely stunt performance. A FMIC would add approx 5' of tubing plus the internal volume of the IC itself
Old Oct 24, 2010 | 08:10 PM
MikeGyver's Avatar
The intercooler did not seem to hurt part-throttle performance until I got my latest cam. I was having idle problems with this cam that I could not figure out how to fix in the tune, so with 03sierraslt's suggestion, I relocated the blower's bypass valve. It now bypasses the intercooler not just the blower, so the IAC is about the same difference from the engine as stock. It seemed to be the change that I needed to get the idle to settle down.
Old Oct 24, 2010 | 11:05 PM
Im having some Idle problems too, do you have any pics of your setup. I have thought about by passing the intercooler for the same reason.
Old Oct 24, 2010 | 11:14 PM
MikeGyver's Avatar
Maybe you saw this?
Old Oct 25, 2010 | 04:42 AM
03sierraslt's Avatar
Told you guys i wasnt smoking crack!
Old Oct 26, 2010 | 08:48 AM
8 Second Club
What blower is in the picture?
Old Oct 26, 2010 | 08:54 AM
Magnacharger MP90 Sidemount
Old Oct 26, 2010 | 11:12 PM
Pocket's Avatar
This is my current setup
Im laying plans for a 122 upgrade and have been pondering if my traditional TB location will be a benefit or hindrance left alone. I do know moving the TB will quiet the blower down at idle/low throttle. Right now it's pretty obnoxious
Old Oct 27, 2010 | 12:12 AM
MikeGyver's Avatar
What are your cam's specs?
Old Oct 27, 2010 | 12:27 AM
Lmfao!!!! anyways a buddy of mine/sincalT/A has a pretty trick set up maybe he'll chime in.
simman22
Jan 21, 2017 10:27 PM
GMCtrk
Jan 27, 2016 06:47 PM
GMCtrk
Oct 20, 2015 06:17 AM
Mr. Chainsaw
Oct 18, 2015 08:00 PM
sTNT971
Sep 11, 2015 02:38 AM
