Installing STS base kit.... help
yea if you dont mind that would be extremely nice man.
nonnie45acp@hotmail.com
IF i can get the muffler to fit behind the turbo i would be doin good. its a 18" overall Magnaflow 6"round.
With no cats and just the turbo, that thing sounds wicked!
I cranked it up to bleed the oil line and test the pump.
Say i do away with all the STS PCV stuff, all i got to wire up is the Oil Pump. Where do i put Catch Cans and stuff. Pics would be good, because i dont know all the "Tech" names.
Thanks alot guys!!!
What sucks bad is, it took us about 6 hours to put it all on and stuff, and about 30 min later we were back to stock..
Thanks alot guys!!!
If you do away with the STS PCV stuff make sure you plug the line going to the passenger valve cover at the TB and vent the valve cover to the atmosphere or to a catch can. If you don't you will pressurize the crankcase when you are under boost. If you vent the passenger side to the atmosphere do the same for the PCV valve on the driver's side or you will draw unmetered air into the intake when you are under vacuum. Also the oil return pump will not be switched to high speed when you are under boost. This may not be a problem at base kit boost levels but will if you increase boost. The oil will back up and flood the center housing and pass into the intake and exhaust.
ogkevin13 - I think you can T off the line from the TB or from the nipple on the back of the intake manifold.
Use a good quality line and run it carefully. If the line gets cut or burnt through the waste gate will not open and you will over boost.
If you run the STS boost control do not use the plastic T that comes with the kit. Get a brass T from a local auto parts store. The plastic T that came with mine broke after a very short time.
hey TGO,, the red hose, did you run that to the Intake
Manifold?
Manifold?
A lot of people have went this route as well.
Glad to see you are making head way.
ARC
57
Feb 21, 2022 10:54 AM
Corvette454l88
Sep 1, 2016 01:24 AM
ZO6Ted
Aug 12, 2015 07:50 PM
