Injectors??? Hp rating??
Old Nov 29, 2010 | 11:23 AM
  #31
2toneblown's Avatar
Originally Posted by 00Z71
Converter box is not hard to do at all...
Honestly thats what would keep me from switching, but now that I did it... It was alot easier than I thought..
Just 1 more thing to go wrong and spend money on. Personal preference and opinion.
Old Nov 29, 2010 | 11:57 AM
  #32
TX Tahoe Z71's Avatar
Originally Posted by Rick_Vor
How much did he charge to resize them?
$25 per injector plus $6 shipping. He says he enlarges the holes on the bottom of the injector so they act the same as the 47lb would, but flow 75lb.
The unmodified injectors are $225 shipped, see this thread for details: https://www.performancetrucks.net/fo...d.php?t=463971
Old Nov 29, 2010 | 02:52 PM
  #33
SLO TRUCK's Avatar
Originally Posted by smokeshow
Hey stock48 runs 60lb injectors and makes 1100hp. He may or may not have a few additional meth injectors, but thats beside the point
I am pretty sure he is running the 1 or 2 of the biggest meth nozzles he could find. (if i read right.)
Old Nov 29, 2010 | 05:10 PM
  #34
TrickTurbo's Avatar
Truck Sponsor
Meth, injection hope I don't need it. So much going on already, but if the IC parts don't do their job its always an option.
Old Nov 29, 2010 | 07:21 PM
  #35
FarmTruc's Avatar
Performance Trucks Sponsor
Originally Posted by 2toneblown
I just opted to spend $400 and get FAST 85#s and call it good. No BS converter box and tuning time and idle problems.
agree, it's preference, but by no means do the low imp injectors idle worse than the high imp inj.
the low imp inj's run better, idle better and tune better than high's, that's already been proven.
the converter box is easy to install and very simple. as long as the wiring is good, there won't ever be a problem.
not trying to convince you, i'm sure those 85's are more than enough.
good luck with your setups!
allen
Old Nov 29, 2010 | 08:28 PM
  #36
schino's Avatar
allen. im shooting for 550 at the wheels and think 60's would be good but would you suggest running the low imp box with larger injectors to cut the duty cycle? just wondering whats the better route. also if you could pm me price
Old Nov 29, 2010 | 08:53 PM
  #37
SRTKLLR's Avatar
Originally Posted by TrickPerformanceProducts
Been reviewing a little but still missing what I am looking for.
Is there a break down somewere showing whick injectors are good for what horsepower to the ground.
600?
800?
1000?
If there's a charge please link it?
First, what are you putting them on? I mean are they Multech, EV-1(minitimer), EV-6(USCAR) EV-14 etc?
Modern cars/trucks use the EV-6(USCAR, LS3) type injectors. The biggest I have seen is 91lbs/hr @43.5psi. But you can get an adapter to go from EV-6 or Multech to EV-1.
To calculate how much power your injectors are good for I use the following site. They have a very good tech section that calculates hp ratings based on injector size, BSFC, IDC etc.
Here is the link: http://www.rceng.com/technical.aspx
Old Nov 29, 2010 | 09:05 PM
  #38
Flaco's Avatar
8 Second Club
i am going to agree 100% with Allen on this, i just switched from 83 highs on lil sis to 160's low and this thing idles like a champ, before if i would try to lean her out to mid 13's it would surge real bad, now i can idle her at 14 afr without a hiccup..
Old Nov 29, 2010 | 09:11 PM
  #39
TrickTurbo's Avatar
Truck Sponsor
02 Chevy truck, Whipple set up. So I guess that would be old school stuff these days.
Old Nov 29, 2010 | 09:25 PM
  #40
SRTKLLR's Avatar
Yeh, those are the Multech II injectors. I have some custom 60lb/hr Mulech's on my 03 Silverado. I think I talked to you(Rick) about them a year or so ago.
I punched in 800(crank) hp with a BSFC of .55 and fuel pressure at 58 psi with 80% IDC(injector duty cycle) and it says you would need a 60lb/hr injector. If you go to 85% you need 63lb/hr to go 900hp. Some go higher on the duty cycle but it is not recommended as injectors stop flowing in a linear fashion.
My injectors are currently at 30% IDC because I have not installed the turbo yet but I am hoping for 800 crank hp once I install the hot side kit I got from you.
BTW, the injectors on my truck flow 72lb/hr at my rail pressure of 58psi(4 bar) and all I did to the tune was change the IFR from the stock 25lb/hr to the current size and they idle like a champ.
Problem is when you change to an injector not made for us. Because they have different characteristics(battery offset voltage, min/max values etc.) so they sometimes don't idle good. I read some good info on the Yaw Performance site a while back ago that talks about that.
