im sure this is an elementary question
Old Sep 25, 2008 | 04:10 PM
silver-mod-o's Avatar
Hunt&Fisherator
Default im sure this is an elementary question
Just wondering where on the manifold I need to tap for a reference for my boost guage install... Like I said, I'm sure its a simple answer, I just don't want an innacurate reading.
Also, what should I do about my PCV system to prepare it for boost???
Old Sep 25, 2008 | 04:18 PM
7845's Avatar
Banned
i tapped off back of my intake. its where the little nipple is. good size. my map and boostcontroller dial is all off this port
Old Sep 25, 2008 | 04:26 PM
02BlueStepside's Avatar
On the passenger side, under the plastic cover if I remember correctly. You will have to snip the plastic cap off, and then you can use the port.
Old Sep 25, 2008 | 04:33 PM
Hunt&Fisherator
Well I know 7845 is running something other than a truck intake, aren't you as well 02? I'm sure there's somewhere back there to use, just haven't dug around too much.
Old Sep 25, 2008 | 04:35 PM
7845's Avatar
Banned
on the truck intake. there is a port on the passengerside i do beleive. its about middle of intake at the topish. i remember using this port for my n20 setup on the 5.3. this is same port you can use for reference
Old Sep 25, 2008 | 04:56 PM
charcold-bowtie's Avatar
its there ben. just take look at the pass side. It opens like a coolaid thing lol. Just snap the end off then theres an open port. IIRC you dont have a engine cover
PCV is an argument. Right now i removed the hose to the TB. plug the tb port and have a one way valve on the drivers side to stop the boost. Pass valve cover has a breather. I plan on taking that breather off, and running that hose through a cathc can and into the air filter to have vacum
Old Sep 25, 2008 | 05:19 PM
1BADAZZSS's Avatar
I am pretty much doin the same thing on the pass crank case vent. Except since my air filter is in the back off the truck. I am just goin to stick a small air filter over one of the hose bard ends on my catch can.
Old Sep 26, 2008 | 03:03 PM
Nope, stock truck intake here
JordanH
Dec 25, 2015 08:32 AM
pewter00
Sep 13, 2015 11:14 AM
TAPyvehc93
Sep 12, 2015 08:19 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
