Turbo towing
Old Sep 25, 2008 | 08:30 PM
xxwackerxx's Avatar
Default Turbo towing
got my STS set up with the T76 with 42lbs injectors,meth injection...im puttin it all on next weekend. my question is am i gonna have problems towing. i seperate from the air force in about 9 months and im driving from new mexico to PA with a car hauler...i mean am i gonna be boostin all the time and causin really bad egt's or what? appriciate anything
Old Sep 25, 2008 | 09:16 PM
Silver_TransAm's Avatar
11 Second Club
You will be fine. That light of a load, you probably wont even know it's back there till you hit a hill or something, but even then you will be fine. I know this becaus my dads 8.1 has twin rear mounts on it and pulls a fifth wheel travel trailer about every month and has not even seen more than 5psi going up a hill in OD on the 10psi setup.
Old Sep 25, 2008 | 10:10 PM
nonnieselman's Avatar
i tow with mine all the time.. i love it... Meth will help you also..
WHo is doin your tune?
viciousknid's Avatar
Where's the Beef?
Guys in Turbo Diesels tow under boost sometimes so I don't see a difference aside from the difference in Low End torque.
One thing you should consider is Gearing. A 4.10+ will have a better low end for you and take you longer to get into boost. As apposed to 3.43's or so that will get into boost a lot quicker.
Old Sep 25, 2008 | 10:14 PM
Stoichiometric's Avatar
The EGTs would be something to watch if you were towing heavily. You can melt stuff but that is based on load and time. If you are in boost for a long time up a hill you can drop it into 3rd to ease the load up.
Old Sep 25, 2008 | 10:51 PM
Wilde Racing's Avatar
How do I change this text
Towing with a gas turbo is tricky. Like Stoichywhatever said, watch yor egts! What really gets the egts up there is going into boost while running 14.68 a/f. you may not clear all the requirments for your p.e fueling to be enabled as the boost will come on much sooner and at lighter throttle positions.
Towing with a diesel turbo vs. gas turbo. More fuel for a diesel = higher egts. more fuel for gas = cooler egts....
In short, Tunning is key
Old Sep 25, 2008 | 11:03 PM
Good point, I forgot what PE was.
Old Sep 26, 2008 | 06:55 AM
xxwackerxx's Avatar
Westers is gonna due my tune this week, ive talk to them a few time and they sound like they got the schit together so...also i got 3.73's. well it depends on the AF weather or not how heavly the trailor is. now they say they wont ship vehicles on a seperation so ill be haulin the wifes subaru impreza my 1984 FLH shovelhead and my polaris sportsman 500. with some odds and ends. im gonna talk to westers to see if they can hook me up with a few tunes on the ol diablosport to help combat any problems on my trip, like elevation changes and what not...
Old Sep 26, 2008 | 08:41 AM
Do you have a a/f ratio and egt gauge? Elevation changes wount change much if you turn the truck off at your "pit stops" along the way allowing the pcm to relearn the atomphric pressure.
Old Sep 26, 2008 | 08:47 AM
Like he said... a Wideband would make me feel alot safer on a long trip towing.
You have a Trans cooler?
