im sure this is an elementary question
Just wondering where on the manifold I need to tap for a reference for my boost guage install... Like I said, I'm sure its a simple answer, I just don't want an innacurate reading.
Also, what should I do about my PCV system to prepare it for boost???
on the truck intake. there is a port on the passengerside i do beleive. its about middle of intake at the topish. i remember using this port for my n20 setup on the 5.3. this is same port you can use for reference
its there ben. just take look at the pass side. It opens like a coolaid thing lol. Just snap the end off then theres an open port. IIRC you dont have a engine cover
PCV is an argument. Right now i removed the hose to the TB. plug the tb port and have a one way valve on the drivers side to stop the boost. Pass valve cover has a breather. I plan on taking that breather off, and running that hose through a cathc can and into the air filter to have vacum
TAPyvehc93
Sep 12, 2015 08:19 PM
On the passenger side, under the plastic cover if I remember correctly. You will have to snip the plastic cap off, and then you can use the port.
