IC coolant level drop, whipple 2.9L
Old Aug 29, 2016 | 08:51 AM
rjw's Avatar
rjw
From: Tinker till it blows, then back it off a notch, maybe!!
Default IC coolant level drop, whipple 2.9L
I seem to have to be adding coolant to the intercooler fill a little more often than I'd like to. I am wondering if there is a leak in the heat exchanger under the sc, in that there are NO external leaks.
anyone?
Old Aug 29, 2016 | 09:06 AM
03sierraslt's Avatar
That's possible. Any abnormal smoke from exhaust? Check a couple plugs, see how they look. You should t have to add any.
Old Aug 29, 2016 | 11:10 AM
rjw's Avatar
rjw
everything looks fine, plus had it pressure tested and it hold fine.
I think that it's just purging air.....time will tell
thx
Old Aug 29, 2016 | 12:10 PM
07Softail's Avatar
I would say the IC is just burping air right now and should level off shortly.
RT
Old Aug 29, 2016 | 03:03 PM
Vortec350ss's Avatar
How long has it been on the truck for? I would agree its just purging air. Keep adding fluid to it in the short term. This kit has the tank down low, right? Air bubbles may take a while to work themselves out.
Old Aug 29, 2016 | 06:06 PM
07Softail's Avatar
Yes behind the bumper and it's 4 gallons.
RT
Old Aug 29, 2016 | 06:51 PM
rjw's Avatar
rjw
been topping off for about a week......but no leaks, internal or external, so just need to burp it....thx
Old Aug 29, 2016 | 07:36 PM
Gadgetized's Avatar
How much have you added? When you pressure checked it, did it hold air? If it didnt hold air, be careful. It could leak into a cylinder and cause some major damage when you try and start it.
Old Aug 29, 2016 | 07:49 PM
rjw's Avatar
rjw
It held 15 psi for 10 minutes, so I am not worried anymore about internal leakage.
We've added small amounts for 5 or 6 days (maybe 1/2 or more of the small filler reservoir. I've gone thru this in the past with less than perfect IC/tanks setups, but I'll know for sure in a few days
Old Aug 29, 2016 | 08:09 PM
Gadgetized's Avatar
Ok. Sounds like you have it covered.
