IAT wiring question
Old Oct 17, 2006 | 06:30 PM
foxySS's Avatar
Thanks Justin and Wilde Racing, I guess I will go that route. What I originally was gonna do is just run all new wires from the new IAT straight to the PCM.
Old Oct 17, 2006 | 06:35 PM
Mort's Avatar
If you wire the IAT directly to the PCM you have to delete the one in the MAF. The PCM is only set up to run one IAT signal.
Old Oct 17, 2006 | 06:43 PM
dc_justin's Avatar
Hello Dave
Originally Posted by NubzSS
i have the 03 whippled ss. same situation as foxyss..
Hey Nubz, whereabouts in So MD do you live? I recall a guy at Speed Unlimited near Andrews AFB that mentioned someone in the area with a whippled SS, was that you?
Old Oct 17, 2006 | 07:10 PM
foxySS's Avatar
I was just going to clip the factory wire coming from the MAF. Was gonna do it about six inches away from the PCM and then solder the new wire on in its place.
This other method should work just fine if I can locate the wires correctly.
Old Oct 18, 2006 | 11:48 AM
2004SSS's Avatar
i just did this to my vortech , i cut the wires about 8 inches from the maf and then connect them to the new iat harness and didnt need to add any wire , it came out nice , now i can see how hot my **** really gets but surprisingly enough they dont get that hot.
Old Oct 18, 2006 | 05:34 PM
foxySS's Avatar
Thanks Chase. Yeah, I cut my wires about the same length from the MAF. It was a PITA to route the wires back through all the stock spaghetti tubing to the manifold, but I got her done. Works like a charm.
slowmo934
Sep 9, 2015 12:24 PM
713truck
Aug 18, 2015 09:32 PM
USMCvet0311
Aug 1, 2015 07:45 AM
