IAT wiring question
Originally Posted by NubzSS
i have the 03 whippled ss. same situation as foxyss..
Originally Posted by Mort
If you wire the IAT directly to the PCM you have to delete the one in the MAF. The PCM is only set up to run one IAT signal.
This other method should work just fine if I can locate the wires correctly.
i just did this to my vortech , i cut the wires about 8 inches from the maf and then connect them to the new iat harness and didnt need to add any wire , it came out nice , now i can see how hot my **** really gets but surprisingly enough they dont get that hot.
Thanks Chase. Yeah, I cut my wires about the same length from the MAF. It was a PITA to route the wires back through all the stock spaghetti tubing to the manifold, but I got her done. Works like a charm.
slowmo934
Sep 9, 2015 12:24 PM
