How much boost?
Old Dec 21, 2006 | 02:32 PM
Ruffrider5.3's Avatar
Default How much boost?
Can I run with stock injectors? I have a 255 intank pump.
Old Dec 21, 2006 | 02:56 PM
slowec's Avatar
I peak @ about 7.5 psi . My tune is on the safe side and that happens to be where the 5.5psi spring landed me . I added a 3" straight thu muffler and lost .5 psi. I would not go over 10 without some injection system. Thats just my opinion cause My truck is my daily driver. Keep us informed. I would like to know what your tune ends up at on timing. I think I am way conservative in that area.
Are you still runnin LT's?
Old Dec 21, 2006 | 03:02 PM
Superado's Avatar
11 Second Truck Club
on stock injectors, at less than 8#'s, I was at 100 % DC @ about 4400-4800 rpm...
Old Dec 21, 2006 | 03:13 PM
slowec's Avatar
Oh $hit, I just assumed you had upgraded injectors . Be careful , I think you'll be maxing out the stockers with what your running. Get a wideband and a boost gauge.
Old Dec 21, 2006 | 03:32 PM
I still have long tubes, I wrapped the ypipe and the turbo pipe. I think this waste gate has a 7 psi spring so we will see what we can get out of it, safely of course. What kind of vacuum is ok at idle. I think I have like 10 psi. Then when I rev it it goes to 22 or so.
Old Dec 22, 2006 | 09:39 AM
Mort's Avatar
Cool
I don't think you should go over 5-6 psi boost on the stock injectors. Do you have a boost gauge?
Also I am not sure about your vacuum reference. 9-10 psi of vacuum (ie -9 to -10 psi) is normal at idle. When you accelerate your vacuum should go to zero and then into boost. You say it goes to 22 when you rev? Is that measure in psi or inches of mercury and is it vacuum or boost that it refers to?
Old Dec 22, 2006 | 01:59 PM
Wilde Racing's Avatar
How do I change this text
WOW, I WOULD NOT let that thing build over 6 psi, and no more than 12psi with big injectors IMO.... Get some bigger injectors, FAST!
Old Dec 22, 2006 | 02:05 PM
BadSR71's Avatar
Get AT LEAST 42lb injectors man... You're really risking it with the stockers in there. 42lb injectors on mine at 8psi was even kind of sketchy as far as duty cycle!
Old Dec 22, 2006 | 02:58 PM
Yeah, I am going to local shop tomorrow to get some 42 or 60s, not sure yet. He has the injector adapters in stock and is a friend so I should get something somewhat cheap. I have not put my foot in it yet, but Im itching really bad. Like giving a fat kid a piece of cake and telling him he cant eat it.
Old Dec 22, 2006 | 05:50 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I'd get the 60# injectors right now. Youre gonna need em one day....its not like we ever stop adding power...
