How much boost?
Old Dec 22, 2006 | 05:55 PM
TIM Z's Avatar
11 sec. Truck Mod
Yep, dont chance blowing your motor, get at least 42#ers . go larger if you plan on 10#'s or more of boost.
Old Dec 22, 2006 | 06:06 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
go 60s first and dont waste your money
Old Dec 22, 2006 | 06:13 PM
Stoichiometric's Avatar
If you want to go all out on the injectors, the larger low impedence with a driver are actually easier to tune than a high impedence of the same size. I have not personally ran any of them, but a friend of mine in the know says my 95lbs low impedence will act like stock injectors.
Old Dec 22, 2006 | 06:25 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
You friend is absolutely correct.
They will definitely run better, be easier to tune than 60's, but with the right peak and hold driver you can run high-z's and the driver for the same benefits and upgrade to low-z;s if and when you need 'em.
Old Dec 22, 2006 | 07:23 PM
03sierraslt's Avatar
My 43lb injectors are at 97% with 7lbs boost on my 6.0L Get some bigger injectors right away.
SS94S10
Jan 3, 2019 01:57 PM
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
