how big of pulley can i go?
Old Jul 19, 2007 | 10:42 PM
bgray's Avatar
TOTM: June 2007
Default how big of pulley can i go?
mods below, when i order my blower i want to get an additional pulley..it will be tuned after so im not worried about that, jsut want to know how small of a pulley/psi i cna run on stock internals
Old Jul 19, 2007 | 10:56 PM
thunder550's Avatar
High on diesel fumes
Do you have a 4.8 or 5.3? What kind of blower?
That ASP crank pulley will reduce your boost, might want to consider swapping back to stock when you install the blower.
Old Jul 20, 2007 | 10:01 AM
bgray's Avatar
TOTM: June 2007
soorry..5.3..going Magna Charger
why does ti do that?
Old Jul 20, 2007 | 10:08 AM
ZZebes's Avatar
because pulleys are like rear ends they are ratios. the ASP pulley is bigger than stock thus spinning slower and "underdriving" your pulleys. thats why lightning guys use smaller than stock balancers to "overdrive" there stuff
Old Jul 20, 2007 | 10:39 AM
thunder550's Avatar
Right concept, but wrong way around. The ASP is smaller, meaning that for every revolution of the crankshaft the outer edge of the crank pulley "travels" less distance. Think of it like a smaller set of tires. If you rotate a 28" tire at the same RPM as a 33" tire, you go less distance.
I don't know what the diameters are of the two pulleys, but let's say for the sake of this example that the stock balancer is 13" and the ASP is 11". For every revolution of the engine with the stock pulley, you move the belt 1 circumference, or about 40.8 inches. Now you swap that over to the ASP pulley, and the belt moves about 34.6 inches for each revolution of the engine. Since it's moving less distance in the same amount of time, it has to be moving slower, "underdriving" your other pulleys and making them all run slower. When you underdrive a supercharger pulley, you spin the compressor slower, making less boost.
Anyway, back to your original question. With a stock crank pulley, you will make about 5-6 psi with the standard 3.4" Radix pulley. If you drop that to a 3.0" you will make about 9-10 psi. If you went as low as a 2.8" pulley, you might see 12-13 psi but you will have problems with belt slippage. Most guys on a 5.3 will run either a 3.2 or 3.0".
Old Jul 20, 2007 | 10:58 AM
BlownChevy's Avatar
blownerator
25 Year Member
Negative, Lightings get a LARGER lower pulley to spin the blower faster.
Old Jul 20, 2007 | 11:02 AM
ZZebes's Avatar
It's early leave me alone.
Old Jul 20, 2007 | 11:04 AM
BlownChevy's Avatar
blownerator
25 Year Member
just bustin your chops
Old Jul 20, 2007 | 10:52 PM
bgray's Avatar
TOTM: June 2007
sick guys..thanks for the info..look like i'll get a 3.0 when i get my kit...and i'll get it from blown chevy also
Old Jul 20, 2007 | 10:58 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Smaller blower pulley's/larger crank pulley's= more boosty's
