Homemade Turbo Kit
Old Aug 2, 2007 | 01:30 PM
gotboost30's Avatar
Registered User
I built a kit for my expedition here are some pics
This is the first setup I did with the stock 120k 4.6 motor Its Different now
Old Aug 2, 2007 | 05:21 PM
Stampede4ever's Avatar
That's bad as hell, you won't see that every day. What turbo did you use?
Old Aug 2, 2007 | 05:34 PM
WJ MARK's Avatar
What did you use for tuning? Those motors are already fun to change plugs on. lol.
Old Aug 2, 2007 | 05:41 PM
gotboost30's Avatar
Registered User
Diablo sport chip ECU The Turbo is a Master Power T70 stage custom wheel and a 96.ar
Old Aug 2, 2007 | 05:43 PM
gotboost30's Avatar
Registered User
Thats The old setup
Old Aug 2, 2007 | 05:46 PM
gotboost30's Avatar
Registered User
This is whats in ther now
Old Aug 2, 2007 | 06:04 PM
Spoolin's Avatar
GFYS and STFU
On your old set-up what piping materials did you use? And did you powder coat the crossover and the charge pipes or is that for heat retention? Looks increadible. What is that before the FMIC? Small A/W intercooler or a muffler?
Old Aug 2, 2007 | 08:25 PM
Is that a 5.4 4v? Any hp/tq numbers, et?
Thanks.
Old Aug 2, 2007 | 08:55 PM
gotboost30's Avatar
Registered User
The hot side is Mild Steel 2 1/4"-2 1/2" Turbo Inlet Tubing the Black is VHT which works very good as long as you perp your tubes good 3" Downpipe, Wastegate recirculated The I/C tubes are mild steel Powdercoated The 4"aluminum you see below the I/C is for the Blow through Mass You need a Good section of stright to control the air flow and the truck ran flawless . The new setup the hot side is the same Just Ceramic Coated and I made made a set of Headers customizeing another set of Headers and changeing the Flange to cobra FlName:  DSCN1860.jpg
The motor now is a 4.6 With cobra Heads and Crank Fully Built and cryo treated and The I/C tubes are 3" aluminum Name:  DSCN1967.jpg
Size:  44.3 KB Iam useing a Tial wastegate and Blowoff Valve
Old Aug 2, 2007 | 09:22 PM
gotboost30's Avatar
Registered User
Thanks.
4.6 Iron Block with Cobra Crank and Cobra Heads Fully Built The old setup put down 463rwh 497fpt at 12/13 psi on a 120k stock 4.6 motor (non PI heads )
very important to have a awsome tune . I have turned the boost up to 18 PSI didnt get dynoed but it was awsome but you get greedy and keep turning the boost up until toal distruction .24PSI and boom it all came apart Than 9 months later we have the fully built 4.6 cobra motor with iron block This new set up put down 670 rwh and 750 fpt around 14psi I havent ran it at 14 psi on the street only 10 Psi and I HAVENT BEATON IT I just moved to st paul mn and in the process of selling it any other question let me know
Choda
Jan 22, 2026 02:03 PM
GXPJAY
Feb 13, 2022 08:15 AM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
71ls2
Jul 20, 2015 11:53 PM
Cowboy17
Jul 9, 2015 08:22 PM
