Help! Radix Problem
Old Jan 2, 2008 | 09:53 PM
  #21
laynlow77's Avatar
Originally Posted by 496chevy
is the pulley a one way deal or is it reversable for the "fool proof install"... again, i only wish i had your problem
clint
it is keyed but im assuming it one way as well. i have only seen them with the lettering on the outside.
Old Jan 2, 2008 | 09:54 PM
  #22
moregrip's Avatar
what a rush!
I wonder if sliding the passenger side idler up some would help at all?????
Old Jan 2, 2008 | 09:56 PM
  #23
laynlow77's Avatar
ive wondered the same, but i dont think it does. ive got another shorter belt that ill try tomorrow, so ill be able to put that adjustment up.
Old Jan 3, 2008 | 05:51 PM
  #24
moregrip's Avatar
what a rush!
any updates?
Old Jan 3, 2008 | 08:01 PM
  #25
laynlow77's Avatar
crank bolt has loose....very loose! i took it out by hand, and my crank pulley had come out probably 3/8s inch. went ahead and tightened that back up and replaced the bolt with tons of loctite to factory tq specs. hopefully it holds up, but ill keep checking it now.
and as far as the misaligned idler on top, i never ground down the small part that i was apparently supposed to on the main accy bracket. ill be doing to tomorrow, although ive heard its not a problem to leave it like it is.
Old Jan 3, 2008 | 08:07 PM
  #26
moregrip's Avatar
what a rush!
that means your pulley spun on the crank, pin that badboy like yesterday!
Old Jan 3, 2008 | 08:11 PM
  #27
laynlow77's Avatar
ill call brian tomorrow, know how much one is?
Old Jan 3, 2008 | 08:12 PM
  #28
moregrip's Avatar
what a rush!
80 bucks I think
Old Jan 3, 2008 | 08:16 PM
  #29
laynlow77's Avatar
ouch, thats quite a bit for what it is.
Old Jan 3, 2008 | 08:17 PM
  #30
trever1t's Avatar
2nd fastest 5.3 ECSB
Lucky you caught it when you did, damn!
